Some GOOD News!
They never stopped building them actually. I saw a show just the other day about it. They continue to make them for countries in asia and middle east.
Honda Super Cub in the Honda Collection Hall in Japan |
Also called |
Cub, C100, C102, C65, CM90, CM91, C110, C50, C70, C90, Passport, EX5, Dream 100, EX5 Dream, C100EX, Super Cub 50, Super Cub 110 |
Production |
1958-present |
Assembly |
15 countries worldwide |
Class |
Underbone |
Engine |
Horizontal 49–124 cc (3.0–7.6 cu in) 4-stroke air-cooled single |
Transmission |
3 or 4 speed, semi-automatic with wet multi-plate centrifugal clutch |
Frame type |
Step through pressed steelmonocoque underbone |
Suspension |
Front: Leading link (early), telescopic fork (late)
Rear: Swingarm |
Brakes |
Front: drum
rear: drum |
Weight |
55–90 kg (121–198 lb)[1] (dry) |
The Honda Super Cub is a Honda underbone motorcycle with a four stroke single cylinder engine ranging in displacement from 49 to 124 cc (3.0 to 7.6 cu in).
In continuous manufacture since 1958 with production surpassing 60 million in 2008, 87 million in 2014, and 100 million in 2017,[2] the Super Cub is the most produced motor vehicle* in history.[3] Variants include the C100, C50, C70, C90, C100EX and C70 Passport.
There were/are MORE Honda Super Cubs manufactured that ANY other vehicle in the world. Glad to see Honda bring them back to our market. They were great vehicles for students and others just looking for inexpensive local transportation. And.....over 100MPG
Semper Fi
I own a 1962 c100. The fairing has gone missing. Hasn't run for many years, but I bet that with a fresh battery, an oil change, and some fresh gasoline, It'd start on the 3rd kick.
Go fire it up, and take a lap or three around the yard!
It is good news....
They were the biggest sellers back home. I used to stock cylinders piston rings and gasket sets for a quick top end job. Could have one in and out in 30 mins. They will run forever...
2012 RS sm5
Second bike I owned after a Cushman Eagle, which actually should have been called a Cushman Dog.
I had one very similar, a 1955. It had a down low exhaust which I changed to the one yours had. Mine didn't have the enclosed front fork. I see yours had a front shock suspension. Mine had trailing spring linkages. 40 - 45 mph tops! The 50cc Honda Cub killed Cushman motor scooters. A couple of my buddies who were brothers, had them. Probably some of the very first ones sold in Idaho. That was back about 1960. They could run circles around me every which way.
This one looks almost exactly like the one I had, even the color!
2014 Copper RTS
My buddy told me years ago the crankshaft was pressed together pieces and the connecting rod was a solid circle around the crank. You couldn't replace the piston, just the entire piston/crank assembly.
2014 Copper RTS
A video I found about it, and another new model for 2019...
