support
Originally Posted by UtahPete
I still don't understand what that piece of angle iron does.
20180608_113245.jpg20180608_113210.jpg20180608_113156.jpg20180608_113148.jpg20180608_113122.jpg
Hope this helps
a few mpre
20180608_113105.jpg20180608_113051.jpg20180608_112304.jpg20180608_112155.jpg20180608_111755.jpg
Some better shots with ratchet.
Originally Posted by SpyderJerry
Okay, I understand now, thanks. So, back to one of my earlier posts, the stability issue with putting a Spyder up on a lift like this has more to do with keeping the Spyder stabilized on the jack itself, not the jack itself having any inherent stability.
2014 RTL Platinum
stability
Yes, both Pitbull and J & S have a large footprint. They have no problem as long as bike is supported properly.
What does the Spyder adapter do? I imagine it's similar in function to you D-I-Y solution using angle iron?
2014 RTL Platinum
ADAPTER
Yes
F3
Are either the Pitbull or the J&S jacks designed for use with the F3 chassis?
J&S for F3
So no one knows if a J&S or Pitbull jacks designed for use with an F3 chassis?
Suggest you start a separate thread
2014 RTL Platinum
I dont see why not. As long as it has the frame under the bike it will lift it. yours Should look like the pics in this thread for the frame
