YUP
YUP, i have my allen wrench taped to the underside of the bucket cover.... NEVER had to use it, but it's there just in case....
LIDLOKs are the best...
Dan P
SPYD3R
I heard nothing but good things about them, looks like that might be my first accessory
That would be a very wise choice: they ARE that good!
First class company. One of our locks fell out, and they replaced it. It was at my door before we returned from the trip.
2017 RT-S
Bump Skid - Spyderpops
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
3 PC Mesh Zippered Lid Net Set - TricLED
A arm LED's - Safety LED's - TricLED
Mirror Sequential turn signals
Glo-riders
LED rear turn signals and reverse lights
Front Grills
Third Brake light
Larson Scanner
Light Up - Sue Hopper
I had the same thing happen to mine. I made sure when I put the replacement in to add some lock Tite to the set screw.
Originally Posted by Arion
Obviously I'm missing something important, but if you can unscrew the cylinder with an Allen key what's to prevent someone with a set of Allen keys from doing the same thing? Is my ignorance showing??
I don't think you're missing anything. I had the same thought as I was reading this. While Lidlox may prevent a casual theft, they will do nothing to prevent an act of "cut and run" by someone who makes off with your helmet sans chin strap.
If the lock is so easily defeated by a simple allen wrench, I would have second thoughts on buying them.
My wife and I put our helmets in one of the storage areas on our Spyder. If we don't have room, we will take them with us, even in a restaurant. We've never had a problem doing so.
On the road again...........and forever young!
2013 RT-S SE 5
Yesterday is a cancelled check.
Tomorrow is a promissory note.
Today is cash.......spend it wisely.
Thanks BA. At least if I'm way out in left field I'm not the only one.
Allen wrench is only used after you unscrew the lock with the required key. You would be hard pressed to know this unless you own a set or read this forum. Not that simple.
Did the same.
2017 RT-S
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
Glo-riders
Front Grills
Third Brake light
Larson Scanner
Just remember any lock only keeps the honest people out. If someone really wants what you have, they will finds a way to get it.
2017 RT-S
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
Glo-riders
Front Grills
Third Brake light
Larson Scanner
