Results 1 to 10 of 10
Thread: Brake Adjust
    Jun 2015
    Boise Idaho
    Default Brake Adjust
    So on my 2014 ST-S with the ISCI Hand Brake (my only means of stopping) had become very slow to stop with no bite whatsoever. So I decided that the old pads and or rotors were not sufficient. Bought some ENB Sintered Pads and Rotors from Baja Ron and put them on( easy process by the way ) the braking was not any better. The hand brake does not create the same amount of travel as the foot brake. So I learned how to adjust the the Spyder Master Cylinder and I have great brakes again.
    I will say the adjustment bolt is in an multiple cuss location.
    Just thought I would share that, as no one suggested this solution when I mentioned my braking issue problem before.
    Ready for more myles of smyles.
    Tim
    Default Really😲
    Found out how to adjust the brake and all your gonna say is it's in a cuss worthy area of the spyder..... I am gonna assume that you are talking about the Yoke, jam nut and the piston rod. There is some adjustment there. Had you taken a pic or two and posted them with this thread it may help others that are having problems with pedal height and travel...never-the-less really glad you found a way to make the hand brake work properly for you....
    ​2012 RS sm5
    Jun 2015
    Boise Idaho
    You are right that is the spot. Thought about pictures after I had it all put back together.
    Sep 2017
    British Columbia
    Default photo
    This is a photo of my ISCI handbrake slave and the only adjustment that I am aware of. From what I understand you set it until the brake light actuator triggers the brake light on, then back it off sufficiently to allow the actuator to turn off, then tighten at that spot.
    Jun 2015
    Boise Idaho
    No that adjust makes the lights come on, it was the adjustment on the bikes master cylinder.
    Bossier LoUiSiAna
    Quote Originally Posted by Alwaysonwheels View Post
    thx for the info.
    I went to cheap cycle parts to look at parts view & think I see some adjustment room on piston, however can't seem to post the pic between parts #6-#25
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Jun 2017
    Missouri
    I’d like more info on where to adjust it too. I have the handbrake too and it’s the only way I have of stopping and I’ve never been pleased with it. When someone else gets on the bike they say they can stop a lot easier with foot pedal compared to handbrake. I’ve adjusted where the brake light will come on then I backed off but it still isn’t good enough.
    Jun 2015
    Boise Idaho
    check your PM
    Jun 2018
    Indianapolis IN US
    check your PM
    Could I get that info also or maybe post it here?
    Jun 2018
    Indianapolis IN US
    Tim
    I’ve been thinking about the sintered pads also. Just wondering if anyone has an opinion why installing those didn’t improve your breakng.
