Results 1 to 12 of 12
Thread: battery issue?
    Mar 2013
    Michigan
    Default battery issue?
    Hi fellow Spyder Riders. I own a left over 2012 RT SE-5. I purchased mine in Florida. Shortly after buying the Spyder I moved to Michigan (5 years ago). Whenever I wasn’t riding it I had it on a tender. After this past winter I tried firing it up to no avail. I suspect that the battery is gone despite the tender.
    I had some dash lights for a little while. I did see that it is in 1st gear though but now I don’t have anything now. I need to tow it to the nearest dealership which is about an hour away.
    Any ideas??
    2012 Can-Am Spyder RT SE-5
    All stock no mods
    with the trailer
    Rob Harris, USN, ret
    Thank you all of our future, present and former military for your service throughout the world.
    Jul 2010
    Las Vegas, NV
    Default Battery
    Why not replace the battery? Then ride to the dealer! The toolkit under the seat has the tools you need to do it.
    Joe Meyer
    Default BATTERY LIFE - DEATH
    Quote Originally Posted by rob-airborne View Post
    Any ideas??
    All stock no mods
    with the trailer
    .....I'm a strong believer that people get rid of their Battery long before it's REALLY dead ..... but you have 6 years on yours and this could be the end of it ........ Do you have Star washers on the Batt Terminals ..... They have bad track record of Staying Tight ...... Mike
    Bossier LoUiSiAna
    Quote Originally Posted by cptjam View Post
    By all means. It does not take a dealer to change the battery, & if you have a batteries +bulbs store close by they will probably have a suitable replacement on hand & charged ready to go.
    You will get to know your lil more. (always a good thing)
    Review your manual for proper procedures, should be straight forward, but just to be sure.
    As Blueknight suggested some star washers, would help the connections stay tight, so good time to add them as well.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Sep 2017
    INDIANA, USA
    Default Battery
    Sounds like the battery is dead . I would replace the battery. There's U-Tube videos that are very helpful, if you want to try and change the battery. Most motorcycle shops should be able to change it. Good Luck.
    ENJOY YOUR LIFE WITH A SPYDER
    Apr 2017
    North Central Florida
    Battery issue ?
    Yes, highly likely.
    Is there some reason that you are NOT considering putting in a new one yourself ??
    Having a ~$10 multi-meter around is a really good idea.
    Active Member R FUN's Avatar
    Apr 2013
    Rocanville Saskatchewan canada
    If the battery has been sitting discharged for awhile chances are it will be toast, If you need to change it try to get the YUASA YTX24HL which is the original battery. I have a 2012 RTL and it took 20 minutes to change, make sure you remove the side panel to access the terminal.
    Good luc
    Roger
    2012 RT Limited
    Vertika Floor boards
    Painted rear fender & dash
    Carbon fiber panels
    Utopia back rest
    Baker air wings
    Elka shocks and relocaters
    CB radio
    ISO hand grips
    Tric LED fender light
    Turn signal lights in mirrors
    If your 12 has the original battery--it's probably time. When they quit and die, they are toast. You were lucky in that it happened at home, and not at a restaurant or pit stop over 50 miles from help.
    When in doubt, change it out.
    Mar 2013
    Michigan
    Default Battery issue (still)
    can I go to a local auto store and get a YUASA YTZ24HL battery? Hi
    Idaho
    Maybe, but probably not. Most likely they'll have another brand in the right size. All things considered the YUASA is your best bet. Call around. If the dealer is close just drive over there. Honda uses YUASA batteries so if there is a Honda Powersports dealer close they might have one also.
    2014 Copper RTS
    Dec 2015
    Oakley Utah
    Call them.
    2014 RTL Platinum
    Apr 2017
    USE THE PHONE.
    Some auto stores stock bike batteries and some don't.
    As said, check with other brand bike shops too.
    Likely that specific battery is used in others too.
