Results 1 to 10 of 10
    Apr 2018
    Texas
    Default F3S Battery tender
    Where have you routed your battery tender wire from the battery to on a F3S? I would like to route it to the trunk but have been told that there needs to be a hole drilled and I am not sure how to make it water tight after that? Pictures please
    John
    May 2010
    Knob Noster, MO.
    Default F3T her
    Quote Originally Posted by Revrent View Post
    John
    I have a F3T, but think the frunk (front trunk) are the same for both the S and T. You do not have to drill a hole, or at least I did not. After I took the tub that covers the battery off, connected the pigtail, ran the pigtail up to the top next to the locking latch, and over the side. Then placed the access cover back on with the connector hanging out. I could have left the connector under the access cover, but did not care to. When I hook up the tender I just place it in the frunk where the helmet is (I take the helmet out), and run an extension cord to power it.
    Is it Friday yet? ... Oh yeah, I forgot. I'm retired
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    2014 RT - Testing completed
    2016 F3-T Audio package - Sold
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    John
    There is weather stripping around the opening of the frunk to keep water out.... ??? I have a hole drilled for mine (didn't like it sandwiched in between) about 1.5-2 in down from the top, no problems....
    Chuck
    Nov 2012
    North Las Vegas, NV
    I ran the plug out the side near the suspension.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default BUCKET
    i ran the power cord tru the bucket, with a quick disconnect between the power port and the battery... that way, if/when you need to take the bucket out, you just unplug the cord and you're ready to go...
    Dan P
    SPYD3R
    Very Active Member JkRbbt's Avatar
    Mar 2010
    SD
    Ran my wire out the back side of the battery box, along the frame to the panel on the left side of the bike. Very convenient. (BTW, she is still for sale. Now asking $13,500.)
    Active Member Texas Al's Avatar
    Jun 2017
    Azle TX
    Default battery tender location
    I installed a Lamonster dual power plate wired directly to the battery. then I added a cigarette lighter plug to the battery tender. Now when I need to plug in the battery tender it is easy.
    2021 900 Ace , Black & Gold
    Active Member Kiry's Avatar
    May 2018
    Seattle
    Mine is the same as Blue Star, currently it's wrapped up for the summer season under the liner out of my way. When the riding season is over, I'll take it up and loop it over in the same way.
    2017 F3-L Intense red "Wings"
    Spyderpops Spyclops Light
    Tric LED Headlights and Fog lights
    Madstad Windshield
    Phoenix - Wrap My Spyder
    Lamonster Highway Pegs
    BajaRon Sway Bar
    Rich's Custom Seats
    2017 F3-L , Red/Black
    Active Member GaryinWI's Avatar
    Dec 2014
    Western WI
    Default Batttery Tender
    I did the same as Texas Al with the Lamonster dual power plate and run directly to the battery. It works great. Don’t even have to bend over.
    2017 F3 Limited , Gloss Black with red and carbon fiber accents
    May 2018
    Columbus, Ohio
    +1 I took Highwayman's advice and did the same. works perfectly. the pigtail just hangs over the top suspension member. riding does not dislodge it, and it does not get close to anything hot. I just get off the spyder, reach down and plug it in....
