I need a little help starting my Spyder this morning please
I went to start it to take it to church and when I turned the key on it shows to be in 1st gear and of course it will not start. How do I get it in neutral to allow it to start ..??
any help is appreciated..!
thanks
2016 RT-Ltd
Bajaron swaybar
Spyderpops trunk light
Elka stage 2 front shocks
Extra longbrake pedal
brake modulator
Centramatic wheel balancers on the front and rear.
Rivco dual flag holder
Tricled mirror turn signal indicators
with American and Texas flags
Lamonster Magic Mirrors
missing belt guard
Lambskin seat cover from Smokey mountain sheepskin.com
Tricled 360 degree led Headlights
Lamonster led fog lights
Baker air wings
2019 Silverado Duramax dually
2019 Cyclone 4007 toyhauler
Spyderpops bumpskid w led light
Rivco brand footrest
spydermanexhaust.com exhaust
had my exhaust installed @ Spyder in the hills.
Put your foot on the brake pedal to start if it's in gear.
Reason: Spelling
On the road again...........and forever young!
2013 RT-S SE 5
Yesterday is a cancelled check.
Tomorrow is a promissory note.
Today is cash.......spend it wisely.
I tried that and it still wouldn’t start ..??
2016 RT-Ltd
Bajaron swaybar
brake modulator
missing belt guard
Baker air wings
After it starts the transmission will go to neutral until you shift it into gear.
2013 RT-S SE 5
Make sure your kill switch is off.
2013 RT-S SE 5
when I last parked it I intentionally didn’t set the parking brake so I could roll it to get to the rear tire to check my tire pressure. Not sure if that had anything to do with it ..?
2016 RT-Ltd
Bajaron swaybar
brake modulator
missing belt guard
Baker air wings
Try setting the parking brake after you turn the key on, then try starting.
2013 RT-S SE 5
did that as well. No luck
2016 RT-Ltd
Bajaron swaybar
brake modulator
missing belt guard
Baker air wings
not starting
At this point I would try disconnecting the battery, give it at least 5 minutes and reconnect. Hopefully will reset the computer.
Ok, I’ll try that. Thank you ..!
2016 RT-Ltd
Bajaron swaybar
brake modulator
missing belt guard
Baker air wings
I still don’t understand why this occurred..??
2016 RT-Ltd
Bajaron swaybar
brake modulator
missing belt guard
Baker air wings
2013 RT-S SE 5
YOUR NO START ISSUE
Originally Posted by BLUEKNIGHT911
It takes no battery power to switch to neutral. It's hydraulic.
2018 F3 LIMITED
You need to explain in more detail what you mean by will not start. So you turn on the key. Press the mode button when asked on the screen. Make sure the engine stop switch is in the run position. Press down on the brake pedal. Press the engine start button. What happens then? Absolutely nothing happens? Or do you hear a click noise? Or do you hear a click noise and gauge display goes blank and reboots?
2018 F3 LIMITED
HYDRAULIC
OK help me to understand what moves the Hydraulic fluid so it moves the transmission into Neutral ....... Thanks .... Mike
That wouldn't make a difference. I always park mine in my garage with the brake off so I can move it around.
2015 RTS Special Series
Russell Day Long seat
F4 Customs windshield
Sena 20s
The engine starts first. That spins the oil pump in the HCM. That creates oil pressure. When the engine reaches idle speed for the first time after start. The shift computer tells the HCM to shift into neutral.
2018 F3 LIMITED
If the OP disconnected and reconnected the battery as suggested and the Spyder started it's possible one of the terminal connections had loosened just enough to interrupt the healthy jolt needed to start it and reconnecting the cables solved the problem. We won't know until he confrims what action(s) he took that solved the problem.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
His post is not clear. So loose cable, could be? That has the same symptoms as a dead battery. There was no description of what happened when it would not start.
Disconnecting the battery for 5 minutes is just a waste of time. But could have fixed it accidently this time.
2018 F3 LIMITED
I had a very strange situation with my Spyder when it was about two years old. During the winter it one day cranked very slowly barely enough to start, took a couple of tries to get to start then ran fine for remainder of day, starting and stopping several times running errands. After it happened a second day I pulled battery out, took it to dealer, had tested and found in fine shape. Reinstalled in bike and had same problem following day. Took bike to dealer, told them I didn't need it for remainder of week. They left it in unheated warehouse for remainder of week, hauled it out on a Saturday and it started right up without them doing anything, absolutely no hesitation. Picked up bike and it has started flawlessly ever since. ???
Cognac 2014 RT-S
We just got home from church. To give y’all some more details I didn’t set the parking brake when I rode it about 5 days ago so I could move it forward or backward to access the rear tire air stem. After I checked my rear tire pressure I just left it. I went to start it today and when I turned the key on I first noticed the gear indicator saying it was in 1st gear. I pushed the start button ... nothing. I then set the parking brake then attempted again, it still shows it’s in 1st gear.
Ill go out and disconnect the battery for a while (greater than 5 minutes) and try that. My battery is still in great shape. I’ll see if by some chance my terminal connections came loose when I disconnect one of the terminals.
Mill report back after I do that.
Tgank you for all of the helpful advice ..! Great forum .!!
2016 RT-Ltd
Bajaron swaybar
brake modulator
missing belt guard
Baker air wings
Happy to report that resetting the email by disconnecting the term worked
I disconnected the (-) terminal and waited 8 minutes (gave it a few extra minutes) and reconnected and boom ..! Fired right up ..!!
Tganks again for your help
2016 RT-Ltd
Bajaron swaybar
brake modulator
missing belt guard
Baker air wings
Thanks for responding so quickly ...... If I'm understanding you on this ...... the pump and pressure etc. occurs AFTER the engine starts and provides the pressure to switch into Neutral ...... Well in my orig post I said my engine won't start because it's not in Neutral,..... for your solution to work the engine must be running.......this is sounding like a Catch 22 situation ........ My thinking on this is ..... The bike will never start without some electricity, at some level of power .... the pump doesn't work without the engine providing the power to run the pump ...... So WHY would juice from a JUMP ( on a battery that's putting out max juice ) make my Transmission go into Neutral ???? ........ I'm not trying to obstinate or obtuse about this .....but I'm not seeing the logic in your solution ..... hence my Catch 22 - phrase ...... thanks again for your input .......... Mike
Your Spyder will start in any gear. It does not have to be in neutral. If your Spyder does not start and it is in gear. It is not because it is in gear. Because it does not have to be in neutral to start. For safety reasons if your Spyder is in gear. BRP has added the extra step of making you apply the brake. After the engine has started. A SE model will shift to neutral on it's own.
So you have dead battery and it will not start. Then you attach jumper cables and it starts. Not really a mystery there.
2018 F3 LIMITED
