Page 1 of 2 12 LastLast
Results 1 to 25 of 33
    Default Secondary frunk release....
    Have seen this problem pop up a few times recently so I went to the garage and installed a secondary release on my RS. Would be similar on the other models . I do appologize for the pictures being out of order some but have not fingured out how to re-arrange them once they are uploaded...Hope it helps those that are thinking about it....
    http://www.spyderlovers.com/forums/a...p?albumid=4762
    Can check My Albums in profile or Latest albums
    ​2012 RS sm5
    Dec 2015
    Oakley Utah
    That's a great use for all those extra split-ring key rings that have been accumulating.
    Very innovative use of romex insulator casing as cable 'slider'.
    2014 RTL Platinum
    Nov 2017
    San Francisco Bay area
    I need to spend a couple of days in a garage with you guys just watching and learning
    2015 RTL , Yes Pearl White
    Dec 2015
    Oakley Utah
    Quote Originally Posted by LeftCoast View Post
    And drinking beer. Don't forget the beer!
    2014 RTL Platinum
    Nov 2012
    North Las Vegas, NV
    I have one on our F3L and had one on the seat and the frunk on our RT.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Dec 2015
    Oakley Utah
    Did you make it yourself ?
    2014 RTL Platinum
    Nov 2017
    Beer is on me, whatever you like.
    Bossier LoUiSiAna
    Yes it has thanks & believe that would be 12gauge solid wire if from a residential romex (commonly available at Lowe's& Home Depot) wondering about the length coming from the location you did would not take much. Wondering if old wire hanger would do the trick
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Oct 2015
    Lynden, WA
    Thumbs up Cable release
    Nice work Gene.
    I did much the same on my ST. Made cable releases for the seat and frunk.
    Used 100 lbs test fishing leader and a skinny nylon tube. Now I have to go back and terminate with split rings.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Nov 2012
    North Las Vegas, NV
    Yes, not as fancy as Gene’s just a piece of wire.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Jun 2016
    Harrington, Australia
    Thanks Gene.....you can’t beat a good “photo with description”
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Default THE RELEASE WIRE / CABLE
    I actually made and installed these as a Vendor ..... ( Spyderquest ) I tested a lot of different cable types and found the best to be 1/16 diameter coated stranded wire available by the foot at Lowe's , Home Depot etc, ....... Mike
    Nov 2012
    Pueblo Colorado
    Default I copied Mikes idea and used the 18" steel leaders I got at Cabellas
    If I recall right that was the length of 30 lb steel fishing leader that I led straight left on my Base RT from the latch lever to the black scoop trims where the LTD's and S-s have their fog lights. Back in the matte finish scoop is room for a split ring and insurance that I can always get to it when needed. Thanks for the ideas and especially the pics guys!!
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    The sleeve offers good protection for the cable.
    I wonder if you could use stainless brake line for a sleeve?
    It wouldn't be as easy to squeeze against the wire as the plastic tube.
    Just a thought.
    2017 F3, SM6-basic black, plain and simple
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    Very good idea!
    What do you think about using a bicycle brake cable with its case and a tensioner on one end?
    2018 F3 Ltd. , Black/Dark
    Jul 2017
    sarasota, fl
    Quote Originally Posted by mcalva View Post
    Very good idea!
    another good idea
    someone hurry up and do this
    Active Member OlJim's Avatar
    May 2015
    NE Oklahoma
    Very good idea!
    You guys are way over designing this, it's not like the hood release on your car, you will probably never have to use it anyway. Mine is like Blueknight's for the frunk and and some fishing line for the seat that I terminated in the glove box with a split ring.
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    KISS principle on mine. piece of galvanized wire in frt. piece of insulated wire for the
    seat bent into a ring at the end.both kept out of sight.
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Very Active Member Bensonoid's Avatar
    May 2014
    Benson, NY
    I'm going to hang a new S Drive on my spyder tomorrow, c'mon over. (Photo does not represent the tire I will be mounting. But it does represent the beer I will be drinking).
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Default EMERG PULL WIRE
    Quote Originally Posted by OlJim View Post
    .........Like I said above I TESTED a few types of " Pull cable " and the coated wire was the BEST ..... stiff yet flexible un-breakable and cheap ( per foot ) ..... It doesn't need a separate SLEEVE ....mine has been on and working without a hitch for over two years ( so has the seat side ) ...... For absolute security you can actually run this type of wire from the re-lease arm at the FRUNK along the left side on the RT ( under the Tupperware ) into / thru the back of the rear trunk. where it stays totally hidden and IN-ACCESSABLE to anyone but you because the PULL is in a locked trunk .......................has that for engineering
    Apr 2017
    Queensbury, NY
    Nice idea! Do you plan on installing them at Spyderquest this year?
    Bert
    Nov 2017
    Quote Originally Posted by Bensonoid View Post
    Great choices!
    Active Member LJspydee's Avatar
    Nov 2012
    Casa GrandeAZ/formally WaterlooIA
    Default Manual frunk release cable
    I used a bicycle cable and routed it under the upper LH tupperware panel. 20180526_163100_001.jpg20180526_162756.jpg20180526_162317.jpg
    2013 Silverado 2500HD Duramax
    2017 Honda Pilot
    2018 Maverick Trail 1000 DPS
    2015 RTS SE6 Intense Red Pearl
    2014 35' Keystone Fuzion Impact Toyhauler
    Ultimate Seats passenger backrest, Adjustable wind deflectors, Minitrailer USA trailer, Can Am driver backrest, Corbin passenger armrests, after market hitch, DIY bump skid, LED turn indicaters, cup holders, frunk decal stripes, DIY GPS mount, DIY Gopro dash mount, aux 12v & USB outlets, DIY belt rock shield, BajaRon swaybar, frunk 12v outlet
    Dec 2015
    Oakley Utah
    Quote Originally Posted by LJspydee View Post
    Nice, clean installation. But I wonder how easy it is to grip that swaged knob at the outer end and then pull it?
    2014 RTL Platinum
    Jun 2016
    Gene,
    I’m in the process of installing this now.......thanks very much.......One thing I’m struggling with....How exactly did you attach your cable to the release arm?
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
