Results 1 to 4 of 4
    Member smoof's Avatar
    Aug 2017
    Kansas City MO
    Default Checking signature pic
    Pic test
    how can I rotate it?
    maybee I’ll try on the computer instead of my phone
    2016 RT Special Series
    rear saddlebag LED lights
    Doc's belt tensioner
    underside LED lighting
    Baja Ron swaybar
    TricLED frt A-arm led's
    TricLed led front skid plate
    Default Typical.....
    Phone pictures always come up sideways...if you figure it out let us know....
    ​2012 RS sm5
    Dec 2013
    Open it in any photo editor or image editing package, rotate it, save it, then load it up to display - problem solved.
    They come displayed that way cos when you took the pic, you didn't align your phone or camera with the 'default vertical' setting you have saved on that device, so it's being displayed according to the way your device was set at that time - the way the device was set by you!! You could probably rotate the image in your device's gallery & then save it again in order to get it to display the way you really want it to appear; or you could always select portrait or landscape mode in your phone/camera as appropriate whenever you flip the device from straight up onto its side - well, unless you WANT the pic to display sideways....
    It took me ages to work out what I was doing to cause this, but once I realised my devices have a 'default vertical' & that I should change that whenever I swap the alignment from portrait to landscape or vice versa, my pics started appearing the right way up when displayed!!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Dec 2015
    Oakley Utah
    The forum pics always render in landscape orientation. With portrait orientation pics, download to an editing app, make ANY change, then save and upload. Works for me .
    2014 RTL Platinum
