Results 1 to 9 of 9
    Wa.
    Default Wiring from Spyder to trailer
    I bought a new Lumina XL motorcycle trailer an a Show Cihrome hitch for my 2017 RT Ltd. Where can I buy the wire harness that plugs into the Spyder an then to the trailer plug. The trailer has a flat 4 pin connector. Would like to get the wiring so it plugs in to the Spyder an then to trailer without having to cut an splice any wires. Thank you for your help.
    Active Member michrick's Avatar
    May 2015
    Liverpool, NY
    I'm not aware you can buy a jumper/adapter harness from 4 square to 4 flat. I made my own up if that's what your looking for. Pretty easy to do.
    2016 RT Limited , White
    Active Member OlJim's Avatar
    May 2015
    NE Oklahoma
    Just do a Google search for Can Am trailer wireing harness and you will find several manufactures.
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    actually the I went to Hitchworld to have an adapter made and all you do is cut the flat four in half and fold two halves together and WaLa you have a square four that fits the spyder. I put som white paint on the top of the spyder receptacle and white paint on the top of the folded four so I knew how it went in.
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Arizona
    Default Plug and Play Harness
    Quote Originally Posted by ned64 View Post
    Try checking this one out. Great service from this company and Pierre and he also has install videos.
    http://www.canamspyderaccessories.co..._query=harness
    Do a search on harness and look at all the results - you will see one made for the RT.
    I have both his hitch and harness for a 2016 RT and am very happy with it.
    2016 RT Limited - Red: Purchased from Pikes Peak Motorsports
    Dealer installed: TriAxis Bars;
    Self Installed: BahaRon SwayBar, Bumpskid, Corbin Armrests, Dave's BT Cable, ShowChrome Luggage Rack,Foam Grips
    Wishlist: Fox Shocks, Long Distance Seat, HID Headlights
    Feb 2012
    Spring City,Utah
    If you will go to Can Am Spyder Accessories.com,Pierre has a plug and play wire set for your Spyder which will give you the proper 4 flat to 4 flat. He will even show you how to plug and play it. Pierre is great to work with.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Wa.
    Thank you Denno an pegasus1300. That is what I was looking for. I called an left a message they were probably closed. I'll call Tuesday morning an order the harness. Thank you all that replied.
    Active Member grieppc's Avatar
    Jul 2017
    Apple valley mn
    Default made my own
    Its a jumper.... purchased two pigtails for the jumper wired them together to work properly the spyder has a 4 prong square the trailer has a 6 prong rectangle its compatible with the gold wing or the spyder simply grab the jumper out of the spyder trunk plug hitch-n-go. purchased them from the supplier to auto parts store they were willing to sell retail just happened to be 20 minuetes from my house.
    2018 F3s , Gold
    Wa.
    Pierre ? Called me today and we talked an he had just what I was looking for. I ordered it, just plug it in under seat an run wire down thru an hook it to plug on trailer. Thank you for your replies
