Page 2 of 2 FirstFirst 12
Results 26 to 47 of 47
  1. #26
    wisconsin
    And that's why, I TOW A TRAILER!! Darn it. P.S. Pete.... I hope you get your issue resolved. Mac
  2. #27
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Mad Mac View Post
    And here I was laughing at the H-D owners who need to carry a full complement of spare parts and garage tools with them on every trip...
    2014 RTL Platinum
  3. #28
    Harrington, Australia
    Good to hear it’s working, Pete, and here’s hoping that it doesn’t occur again before you see the dealer.
    I will be moving the install of release cables up my priority list now. Actually, there could be a market for some enterprising young (or old) person to develop cable operated release kits for the various models.
    HeliBars Handlebars
    Kenda Kanine rear.
  4. #29
    Mar 2015
    forrest above Reno, Nv
    Thumbs up The hammer trick !,
    I did tell Jane about " adjusting" the switch with a dead blow or soft faced hammer. Did she mntion it to you?.?? I just knew the tumbler pins in the lock barrel had jammed.
    SO GLAD YOU GOT IT FIXED. Now some powdered graphite, more compressed air, and lots of key move movement ( all to spread the graphite into the tumblers)
    Again --- a great time with you,Jane, and Paul.
    Lew L
    2014 RTS , Circuit Yellow
  5. #30
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Lew L View Post
    I did tell Jane about " adjusting" the switch with a dead blow or soft faced hammer. Did she mntion it to you?.?? I just knew the tumbler pins in the lock barrel had jammed. SO GLAD YOU GOT IT FIXED. Now some powdered graphite, more compressed air, and lots of key move movement ( all to spread the graphite into the tumblers)
    Yup, I'd been tapping on the housing, along with shooting WD40, compressed air and graphite. Nothing worked until I slammed the key into the hole with the mallet, but I wouldn't have had the mallet or thought about hitting it if it hadn't been for your suggestion. Thanks Lew.
    2014 RTL Platinum
  6. #31
    Jun 2010
    Las Vegas
    I had the key barrel on my trailer pop out of position, it had to be drilled out to get into the trailer. Of course the tools were in the trailer.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
  7. #32
    Dec 2015
    Oakley Utah
    don't you just hate it when that happens
    2014 RTL Platinum
  8. #33
    Mar 2013
    Oz
    Who knew that my dad's home repair recipe - if wd40 doesn't work, hit it with a hammer - would work on a spyder? Glad it's all working now.
  9. #34
    Feb 2012
    Spring City,Utah
    See Pete it all works out for the best. If this hadn't happened you wouldn't have had near so much to talk about.It would have been just another everyday meet and greet,now none of us will ever forget the day that Lew and Nova came to town and you and Jane and I all went to lunch with them.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  10. #35
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    I feel your pain , and I'm sorry I can't help with your currant issue ........... Your problem is a perfect example of why I have mechanical PULL wires connected to my Frunk & Seat latches ..... Asking the ignition switch to do more than make the Electrical connection makes NO sense to me ...... If you want more info let me know ..... it was easy to do .... Mike
    X2. also saves wear and tear on the key and switch. i mainly use the pulls.
    glad to hear its working. if all else fails, the BMFH method will do it!!
    [joyce & irvin toms]
  11. #36
    Sep 2014
    USA
    switch is around 230 bucks plus labor.
    You can see the cables under the switch when removing the headlights too. and see if anything is hanging up cable wise. (frunk,seat)
    Good Luck
  12. #37
    Dec 2015
    Oakley Utah
    Update to this.
    The ignition switch has been working flawlessly since I smashed the key into the switch. Even opens the frunk and seat much easier.
    Took it down to the dealer today and told him what happened. He asked if I wanted to replace it anyway and I said it's probably best, since it could fail on me again and leave us stranded at some point. He is going to check first with BRP to see if they will handle it under the recall program. If not, he's pretty confident the Rider's Advantage extended warranty I have on it will honor the repair.
    They will call me when they have a resolution to the payment of this repair; meanwhile, we're continuing to ride the bike for day rides.
    2014 RTL Platinum
  13. #38
    Sep 2014
    USA
    Good choice on having it replaced. Dont forget the truck lock too and if you have matching trailer .
  14. #39
    Dec 2015
    Oakley Utah
    Yes, it will involve all 3 locks. But, hopefully I'll never need to deal with it again.
    2014 RTL Platinum
  15. #40
    Sep 2021
    GA
    Utah Pete, this just happened to me this morning on a short ride. i was able to get back home since it was stuck in the on position, just as you described. Tried WD and some other lubricants and nothing, then i read where you tapped on the key and it released. Whew, thanks sooo much!! Saved me a day of frustration.
  16. #41
    Quote Originally Posted by stubronco View Post
    It's fairly easy to prevent this. Shortly after I bought my first Spyder, in 09 ... I realized having the ignition switch open the Frunk ( and seat latch ) was NOT a good system, for lots of reasons .... So I Created a separate " Cable " to open the latch .... and this is now the ONLY way I open the Frunk .... Do a search, there are many threads / posts on how it's done .... IMHO the way I do it is the simplest and least expensive way .... good luck ... Mike
  17. #42
    Active Member mecsw500's Avatar
    Sep 2021
    UT
    Quote Originally Posted by LJspydee View Post
    Sounds like I should start carrying a hammer! I've already installed a manual cable release for the frunk after having locked the key in the frunk 35 miles from home. Wife left her key at home. Luckily we have good friends.
    Doesn't matter which tools you carry anyway. You can always use whatever you have as a hammer.
    Can Am Syder RT Limited (2021)
    Triumph Bonneville T120 (2018)
    2021 RT Limited , Silver
  18. #43
    Very Active Member SpyderConvert's Avatar
    Catonsville, MD
    Was it a metric hammer?? Glad that you got your situation resolved!!
    2015 RTL, BajaRon Swaybar, LaMonster LED Headlights and Foglights, LaMonster Spydercuff, LaMonster LED mirror wrap, Magic Mirrors, HMT Brake Light
    2015 RT Ltd. , $" extension Black
  19. #44
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    It's good practice to use graphite powder for locks, the copper latches will slide better Lessen wear, also protects for moisture, and I agree with blueknight, that a key is only needed to start the machine.
    I made the latches also, never use the key for the frunk on my f3.
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
  20. #45
    Jun 2015
    Ritzville, Wa
    I came across this online. It's not the most elegant or aesthetic solution, but certainly seems like a simple one.
    https://www.youtube.com/watch?v=rMqmALEtb10
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
  21. #46
    Mar 2022
    Texas
    Lew L
    Not sure if this would be relevant or not, but I've had pretty good success using a dry lubricant normally sold for firearms on my lock tumblers. It sprays in wet, then dries to a slick film that doesn't collect dust/dirt. Might be worth trying. If not, firearm spray bore cleaner will clean/flush it out in an instant.
    Fyre
    2020 RT Limited , Chalk/Black
  22. #47
    Feb 2012
    Spring City,Utah
    Pete I may have missed it somewhere, but did you ever have your switch replaced? If so was it covered under your aftermarket warranty?
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
