Results 1 to 5 of 5
    Active Member TRBorslien's Avatar
    Mar 2018
    West Fargo, ND
    Default Parking Brake Switch Symbol
    I tried a few searches in the forum, but wasn't able to find an answer to my question
    My parking brake switch works great, but the symbol is almost completely worn off. A new switch (710002353) is $56, which is more than I want to spend for a new symbol.
    My thought was to find an appropriately sized decal. No luck with Google searches on that front. I realize that a decal would eventually require replacement, but I could replace eleven $5 decals before I reached the cost of a replacement switch!
    Any suggestions or past solutions?
    Thanks in advance!
    Tony
    2012 RT-S SE5 - Viper Red
    Castle Atom SV Tarmac Modular Helmets
    Sena SMH5 Headsets
    Ultraguard Half Cover
    Hopnel Luggage: Frunk, Top Case, and Saddlebags
    Big Bike Parts Short Spiral Antenna
    Kumho Ecsta AST 225/50R15 Rear Tire - Got almost 18,000 miles before replacement with Riken Raptor
    Vredestein Quatrac 5 165/65R-14 Front Tires
    BajaRon Spark Plugs and Wires
    EBC Rear Pads and Rotor from BajaRon
    Riken Raptor HR 215/60-15 Rear Tire
    Future Plans:
    2013 Cooling Kit
    BajaRon Sway Bar
    High-Mount Brake Light
    2012 RT-S , Viper Red
    Default Try this
    Get some sticker paper for your printer and print up a sheet of them. If your not stuck on having the original Micheals (arts and craft stores) have a nice variety of vinyl letters that you could stick on.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Leather black solution spread over the key symbol. Wipe off the excess and you should have "new" printing. Unless, the emblem is worn down.
    Jan 2015
    Florence, Oregon
    Smile Blank Switch!
    You could consider a blank switch as another anti-theft device. Or use a soldering iron to engrave a label into the switch rocker plate and then fill the engraved label with white paint. Never wear off again.
    If yours is in the same position as mine, leftmost one, why bother; it shows your Spyder gets lots of use. Ride more, worry less.
