Results 1 to 13 of 13
    Mar 2017
    Minnesota
    Default F3T shifting question
    I have a 2016 F3T with the semi-automatic! I have been down shifting manually from 6th to 3rd gear and then let the bike go from 3rd to 1st when slowing down to stop. My question is it ok to downshift manually?
    Active Member Jeffmal's Avatar
    Jan 2018
    Plantation,fl
    Quote Originally Posted by I-Day View Post
    Abolutely!
    Mar 2015
    NE Kansas
    I don't think that you have anything to worry about. I downshift all the time on my F3. If it wasn't ok, I don't think BRP would have given you the option to do so. Ride more, worry less!
    ...... My question is it ok to downshift manually?
    Seeing that the the Semi-Auto gearbox our Spyders run is actually pretty much just the MANUAL gearbox with the addition of a hydraulic clutch & solenoid activated shifting, plus a 'failsafe over-ride down-shift' to protect the driveline & change down if the operator doesn't match road speed to the appropriate gear selection/throttle setting well enough, I would've thought you should instead be asking "is it ok to let it downshift automatically?"
    It's a manual gearbox people; and just like many other hi-tech vehicles out there today, it has some 'becoming more commonplace' hi-tech & sexy gearchange & clutch features that work 'better/quicker/safer/impose less wear than the old school manual stuff' built into it, and it also has some built in protection features so that you can't break things if you miss changing down when you should or if you get lazy.....
    So just drive it & use it like the manual gearbox it is to your hearts content, unless you don't want to, in which case the fail-safe down change feature will look after you, exactly as it was designed to do!
    Ride More, Worry Less!
    Default What they said...
    Shift at the point you feel most comfortable. If you do it like you did on a manual you could save on brakes by using engine compression a bit more...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jan 2017
    Vancouver, B.C.
    I find downshifting with the paddle along with lightly using the brakes works best. I also stop at second gear and let the computer put it in first. Really saves on brake pads if you do it this way.
    2016 F3 Spyder Limited SE6
    2005 Honda ST1300 ABS
    Active Member Kiry's Avatar
    May 2018
    Seattle
    I downshift too, it adds to the fun of the road. Absolutely!
    2017 F3-L Intense red "Wings"
    Spyderpops Spyclops Light
    Tric LED Headlights and Fog lights
    Madstad Windshield
    Phoenix - Wrap My Spyder
    Lamonster Highway Pegs
    BajaRon Sway Bar
    Rich's Custom Seats
    2017 F3-L , Red/Black
    Active Member bushrat's Avatar
    Apr 2017
    Peterborough, ON, Canada
    Default Perfectly OK
    I'm with Peter and the others ... go ahead and enjoy your downshifting/engine-braking. I'm ryding a 2017 F3L SE, and I do much like you ... I manually engine-brake from 6th down to 3rd, then let the Spyder do the last couple of down-shifts by itself. When needing to decelerate, my instincts always have been to 'anticipate' or down-shift well before the Spyder's auto-shift program wants to kick in. I don't do this at excessive revs; my rev count does go up, but never dangerously so. I do like to feel my engine working; I appreciate having that power underneath me fully engaged if I need it. I've had no problems, no worries in my first 12,000 km. Because I do this often, and usually without touching my brakes, I did install an additional deceleration brake light to warn following traffic that I am indeed slowing up; it works independently of the regular brake light and comes on by itself as I reduce speed. As Peter A. says, the SE system is pretty much fail-safe. In an unguarded, inattentive moment one day when first getting used to my new Spyder, I absentmindedly did a down-shift while doing a quick acceleration take-off when I really meant to be up-shifting - instead of going from 3rd to 4th under full throttle, I actually dropped it back into 2nd during a 'goofy' moment. No harm, lots of roar, but the bike and I quickly recovered and continued on climbing back up through the gears. I have 'pushed' my down-shifts on occasion; nothing terribly ridiculous, but the engine has certainly 'braked' very effectively, and I'm very comfortable in its continued safe performance. Hope it's the same for you.
    [SIGPIC]
    2017 F3 Ltd. Intense Red Pearl/Metallic Black topside
    2017 F3Limited , lowered brake pedal Intense Red Pearl w. Metallic Black topside
    Oct 2017
    GA
    In my experience it down-shifts a little too late, when rider doesn't. That make it "jerky". Manual down-shifting works much better for me.
    Apr 2017
    North Central Florida
    Keep in mind that your brake lights will not come on if you let the transmission do ALL of the deceleration work.
    I'm trying to get in the habit of tapping the brakes lightly a couple of times as the speed slows.......regardless of which way it happens.
    You actually can go all the way to zero (or very close) in many conditions without any brake at all but it often is not a good idea to do that.
    Apr 2017
    Keep in mind that your brake lights will not come on if you let the transmission do ALL of the deceleration work....
    Not quite correct...or at least it is possible to have a brake light which works on deceleration alone, without using your foot on the brake pedal. See, for example, the Admore 'Smart Technology' brake light:
    https://admorelighting.com/product/a...ration-safety/. I have this installed on my F3L Spyder (see photo); it is the light bar mounted just above my licence plate and works independently of the regular Spyder system.
    There are a couple of other makes on the market - e.g. 'Gear Brake' and 'Vololights'. All of these are actuated by the deceleration of the motorcycle caused by engine braking/downshifting without needing to tap the brake pedal. Yes, it does mean purchasing an additional light system, which functions separately from and in addition to the main brake light. The Admore is compatible with the CanBus system on newer Spyders; it is a very simple add-on and offers enhanced safety through warning others of your intention to slow down. It can be programmed to strobe flash (at varying speeds), remain constant and/or indicate turns through sequential flashing arrows. Lots of options.
    [SIGPIC]
    Apr 2017
    Quote Originally Posted by bushrat View Post
    Is it necessary to say "with only the stock equipment" on EVERY post ??
    I hope not.
    But thank you for the information.
    Many owners might find it useful; even me maybe.
    May 2018
    Columbus, Ohio
    Absolutely it's ok! I refuse to let any machine on two or three wheels shift for me....ever....I have the SE6, but i always control what gear I'm in, even when slowing to a stop at a red light
