F3L Monster Fuel Injection ECU Flash
I plan on having the ECU s/w upgrade done by Wick-It in Shreveport and need opinions on
the best way to get this accomplished. My options are: It is about a 6 hour run from my
home to Wick-it, get the upgrade, test it out and head home or remove the ECU, pack it up
and send to them for the flash.
So, my main question would be what is involved in removing the ECU or would it be better
to make an appointment and drive there? What kind of turn around time can I expect?
I am in need of some experienced opinions/advice/thoughts on this.
Thanks in advance.
Dray
TAKD IT OR SEND IT ?????
Curious...🤔
Will they flash it while you are there ..?? Seems most have mailed them in and have not heard how the turn around it. Now if they do it on the spot and it is a nice ryde with time on your agenda...go for the ryde always best if they get you all set up and on your way tuned and happy....
My input
I just sent mine to MFI in Canada last Tues.by 2-3 day USPS...Still have NOT heard anything or received a payment request...
Why did I send it to Canada??? Because if you need or want any future updates they are free (except for shipping)...And I'm planning on changing my RTS to the 89T rear sprocket if and when Steve gets it perfected...He thought he had it working correctly but it showed up a glitch...
Sending anything to Canada is ALWAYS A PAIN IN MY A**...
My advice, Talk to Larry or Coleman at Wick-it-Perf. and see if you can set up an appointment...These two guys seem like a first class act to me...Go For The Ride...
larryd
The best I can tell you is that it takes a few hours for opening and closing the case and doing the flash, and then a while longer for the sealant to set up. When I sent them mine I shipped it Friday, they got it Monday, Flashed it, and put it in the mail Wednesday, and I got it Friday. There is nothing to removing it, only 3 screws, and two connectors to disconnect and they are easy. The gys at Wick-It are very easy to talk to, give them a call.
How old would you be if you didn't know how old you were?
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
What surprised me?
When I was at Monster fuel I was surprised that it takes 2 to 3 hours for the flash to update into the ECU. Blew my mind as he explained how few can be done in one day on one computer.
What I was also told is that Wickit has to pull the the ECU file information and zip it to Monster fuel. Then Monster Fuel returns the file back to them for the install. I'm not sure how fast this part of the process is.
With everything that has to line up it's hard to see that happening in just a few hours.
I apologize if I am wrong as I could easily misunderstand the process?
Just wanted to share.
Dennis
Please do a few time test
Hi Pete, could you take some time to do some base line testing. 4th gear is where a flash really starts to show it's gains. Maybe do some 4th gear roll on time testing 30 mph to 60 mph? Or a country telephone pole to telephone pole and see if there is any speed gains in that distance. It doesn't have to be precise.
At my test track my 2016 F3L went from 104 mph stock to 116 mph flashed through the speed trap. For me and the way I ride the I really like the performance uptick in the 5K to 7k range. My Flashed and piped Spyder is a total Hot Rod and moves like the early muscle cars of my younger years. Just a blast to drive.
My Stock 2016 F3L with the 89 tooth sprocket had RT level restrictions. I had Monster Fuel upgrade me to the F3S Flash which opened my top end up. I used to fall flat at 105 mph but now I pull strong to 115 mph.
I'm really pulling for Jase and want to get some factual results not just feels like and such.
Thanks
Dennis
Originally Posted by Peteoz
Yeah, I’m getting mine done by Jase very shortly, Dray. Same as you....6 hour ride....I thought about taking it out and mailing it, but it’s too good an opportunity to get out for a ride. 6 hours up the coast freeway and a couple of days back through the inland high country
Pete
