Help in identifying this connection.
phpiH6hvzPM.jpgphpNSHfGxPM.jpgPlease help identify this connector. I was under the front of my 2011 RT5 Manual. I was installing Ron's Bar. This connection was unplugged. I could almost not touch it. It appeared to have die-electric grease on the metal parts. Anybody know what it does and where it goes. Everything on the machine seems to work! It is in close quarters. I did not have the front trunk off or I would have been able to see more. What's this thing for? Thanks.
Ride safe!
2018 Spyder RT Limited
It's for the optional 12V power plug in the front trunk. Because it's not connected you don't have that option.
2018 F3 LIMITED
When I had my 2011, I ran connectors and wires to that plug and installed an outlet near the dash to power my GPS.
Lin
2016 RT-S Special Series
That plug only turns on when you open the frunk how did you keep constant power to the plug when you installed your stuff? I know its on a switch .. Did you jump it or?
That plug is on all the time, not on a switch. It's the frunk light that's on a switch. That plug is fused together with the accessory outlet in the rear trunk. I didn't like the idea that the plug connectors were exposed to the elements - even though they had dielectric grease on them - and since I didn't hook it up to anything, I plugged the hole to keep it clean inside.
Doug
”Freedom is not a loophole”
Originally Posted by Snowbelt Spyder
That plug is on all the time, not on a switch. It's the frunk light that's on a switch. That plug is fused together with the accessory outlet in the rear trunk. I didn't like the idea that the plug connectors were exposed to the elements, and since I didn't hook it up to anything, I plugged the hole to keep it clean inside.
OOps your right..
Well thanks guys. I wasn't losing much sleep over it but it's nice to know. Whenever I take the trunk off I'll have to do something with it. Can't let it go unused!
Ride safe!
I actually found I had access to it from the left side by the wheel and through the A-arm without removing the front trunk. Maybe mine was hanging out there where it should not have been.
Lin
Lin
I could touch it from the same point. With one hand. That was as far as the hand could go. So without a second hand in there, there was not much I could do. You see I had to use a dowel just to turn it to get a picture. That's ok, it gives me something to think about!
Ride safe!
