D.E.S.S. Error
2014 RSS , Sunburst Yellow and Steel Black Metallic
Did you take your key and do the "walk of shame" with it?? Might be the first thing to do. Mac
Bummer.....
If you get it going get it to a dealer and have them change it out cause is seems it only get worse till it will not work ever again...
2012 RS sm5
Yeah, tried that, no luck. Tried both keys, still no luck. Read a forum post on a can am ATV forum about grease in the ignition getting wet and causing a short, might be some merit to that...
Spray some WD40 into the keyhole for a temporary fix
I sprayed WD40 in mine and it worked as a temporary fix. My DESS is disabled now, so no more worries.
If only I had some WD 40... or a Spyder i could get to the store on... Thanks BRP.
How do you disable the DESS ??
IBA #47122
2020 RT Limited Asphalt Grey
Compressed Air in Keyhole... direct results.... started... had tried at least a dozen previous starts, including right before the air.
He has B.U.D.S to disable the DESS
Right, this is not a lubrication or cleanliness issue. This is all about RF communications between the DESS module and the chips in the keys. The module is the problem. If you find an independent tech with BUDS and a master tech license, they can disable the system for you. A dealer won't disable it for you. Other wise, as Mike said, replace the module before it leaves you stranded in the middle of nowhere.
Doug
”Freedom is not a loophole”
Exactly!
Originally Posted by Navydad
My 2015 has done it five or six times and every time it was when the bike was wet and water had collected around the ignition. I haven't found any write ups or posts that specifically blame moisture, but I have never had the issue unless the bike had been washed or sat uncovered in a hard rain.
I dont think BRP really knows what the issue is and is just replacing the modules. But then you hear about people having the problem return. Then they have the ignition replaced, blaming the antenna, and no more problems. This problem is not unique to Spyders. BRP ATVs have the same issue, but are exposed to much more dirt and water. WD40 showed immediate results for me(suggested from the ATV forums). Now I have B.U.D.S. diagnostic software and have disabled the DESS so it will never leave me stranded.
Customer Support
Hmm, not that we get a ton of rain here but maybe I’ll come up with some sort of ignition cover.
Strongly recommended you READ about the DESS issue started by Deanna about 3 years ago and that goes for all the others that THINK spraying it with all kinds of %$# is even an answer!
AJ
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
You can read that thread and draw whatever conclusions you want. Like I said, some people had the module replaced multiple times and still had the problem and ended up having the ignition replaced. WD40 will not harm anything, so give it a try. Do not leave your key in the ignition when you wash your spyder. This will prevent water from getting in it. If you read the ATV forums, they have lots of DESS errors and have been diagnosing the problem longer than spyder owners have. The consensus they have come up with, is that water is getting in the switch, mixing with the grease in the switch, and causing poor connections in the switch. They all recommend spraying WD40 or rubbing alcohol in the switch to solve the problem. If you can find someone with BUDS and a megatech license, then get the DESS disabled and never worry again. Good luck!!
Mine was never wet when my started acting up. I replaced the module last year and have been problem free since. Some have had to do both ignition switch and module.
Some have turned bike on and off fast,some have sprayed WD40,some have tried there other key.
Take it to the dealer for repair and make sure BRP get notified too.
Good luck
Take a look at the "Thread D.E.S.S. KEY CODE AGAIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!" that I had started. It has a lot of excellent information. It is a long thread. Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
[QUOTE=CarolinaSpyderRyder;1361846]Was going on a road trip today... but...20180518_154258.jpg[/QUOTE Have the D.E.S.S. module replaced, and the switch replaced, get the keys reprogramed the same time. Have your dealership open up a case with BRP.
I had the switch/D.E.S.S. module replaced 3 years ago. Since then I have not had the D.E.S.S. error show up.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
Was the water from rain or washing the bike? In either case it MIGHT be the reason. Water affects radio waves. The DESS uses an antenna to send a radio signal to the key which then responds with a code via radio wave. It MIGHT just be possible there was enough water around the ignition switch to affect the radio waves. I think they are very weak signals so it wouldn't take much to mess them up. See what happens after you've dried everything off really good.
2014 Copper RTS
The ignition switch already has a cover: the inner flap that closes upon key removal. To avoid water in the switch, I always remove the key when washing and when parking anywhere not under a roof. Otherwise, water can run down the key, into the switch.
NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
Retained the old mirrors with TricLed Signals
General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
Riken Raptor HR.........rear tire (at 114,200 miles)
Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
Gear Brake Decelerometer Module
OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
BajaRon Anti-sway Bar
Kumho ECSTA AST rear tire (at 14,200 miles)
TricLed Turn Signals in Mirrors
Waterproofing Switches & Ignition switch
See this thread posted some time ago
The covers are still in use
http://www.spyderlovers.com/forums/s...165#post566165
Eddie Sheppard
Poole Dorset UK
Get a Spyder - See the World
Moisture is NOT the issue
My 2015 RT Limited has NEVER gotten water anywhere near the ignition at all and yet I have had to replace the DESS module Twice and the 2nd time my dealer had me go buy a new key blank and they programmed the new key and so far, Knock on wood, it has been working fine. They said one of the two keys I had reported a bad chip that was why they had me replace the one key. Just my two cents and experience.
2015 RT-Limited SE6-TricLED Fender LED's (Red and Amber), 3rd LED Brake Light/Tail Light, ISCI Handbrake with black small hands handle,Spyderpops Rock Guard. ,Can-Am Adjustable Wing Vents, Bumpskid, Bajaron's Sway-Bar with metal Heim Joints. Elkas Stage 2 Plus., TricLED Wide-VU Mirrors, TricLED Jumper Port, Laser Aligned!
My comment/speculation above was NOT directed at water entering the ignition switch. I don't think that is an issue. I'm referring to water external to both the switch and key and in the path of the radio signal between the two. Yes, I'm speculating, but as I see it, it is in the realm of possibility.
2014 Copper RTS
Moisture is NOT the problem only when it is NOT the problem.
Moisture IS the problem when it IS the problem.
In other words, moisture has not been claimed to be the ONLY problem.
(But please indulge my recalcitrance in (mis)using "issue" as a synonym for "problem.")
