Originally Posted by Easy Rider
BAD advice, especially for "wet cell" batteries and other types to some degree.
Most last longest if kept within 10% or so of fully charged.
Different rules apply for the old NiCad rechargeables and some of the newer designs.
Lithium cells seem to like to be used.
Like I said I do not know and have no facts. I have been told by several people not to leave a tender on all the time. I have been riding motorcycles for over 60 years. The first Battery Tender I got was in 2005. Like I had said I only used it in the winder and I would just leave in on for maybe one night then leave it off for three to four weeks then put it on for one night. I have had six bikes since 2005 and I have never had any battery problems. I will continue doing as I have and if it goes down I will replace the battery at that time.
Asphalt Grey
Lamonster RT phone mount
Sena SMH-10
Lamonster Belt Tensioner w/ larger roller
Spyderpops Missing Belt Guard
Garmin's GPS
gerald37 you really don’t know what a battery tender’s purpose is do you. Plug in the tender and walk away. It will only come on when the battery needs to be recharged. And then it shuts off,,,, completely. Every battery known to mankind looses power when just sitting. You’re using your tender as a charger. If anyone following this thread is getting a little bit dizzy from the back and forth of these conversations,, just Google it! There are a lot of very smart people on this forum but as you can see there is a lot of confusion for something so simple. Plug it in!!!
SilverFox
If you don't change anything,,,
nothing is going to change!
Not to steal post, but also a newbie with a 2016 F3-T that does not have a battery tender pigtail installed. Looking for a convenient location for access to plug. Have searched but everything shows to drill hole in frunk. Looking for clean look and convenient.
SilverFox
I have said twice I have no facts and I'am probably stupid compared to you but I have never had any battery problems and will continue doing what I have been doing.
Asphalt Grey
Sena SMH-10
Garmin's GPS
When I got mine, I thought I didn't have it installed. It ended up hiding behind the computer access panel in the frunk. Have you looked there?
2017 F3-L Intense red "Wings"
Spyderpops Spyclops Light
Tric LED Headlights and Fog lights
Madstad Windshield
Phoenix - Wrap My Spyder
Lamonster Highway Pegs
BajaRon Sway Bar
Rich's Custom Seats
Apparently he is not the only one who doesn't grasp all the details.
Some shut completely off but most drop down to a low "float" voltage and stay there until a bit of a charge is needed again.
You have a problem drilling a small hole out the back of the frunk to attach to the battery ?
If so, why ??
Nobody will know it's there but you.
Where in Central Florida are you ?
outlet in trunk can be used with cigarette lighter adapter
Not sure which model you have but on our 2014 RTL there is an outlet in the rear trunk for using a cigarette style adapter for power. This can be used for a Battery Tender adapter as well. The fuse up front "may" need to be moved over to a different slot for this point to be "live", but that's easy to do. The manual even mentions it.
Ray & Marci
Tenino, WA
2014RTL Cognac
ALWAYS ride 2 up.
If so, why ??
It's a dry space, and do not want to mess with that. If it comes to that i will. Would just like to untuck the lead from somewhere and plug it in and when done just tuck it back.
We are located in Longwood. This is wife's ride, traded up from a Victory Cross Country, she is ecstatic, just got to get past all this rain.
Sorry, but I do Know exactly how a Battery Tender works but I guess there are two of you that don't understand that some people want to be sure their Spyder will start without a Battery Tender on all the time. If my battery is weak I want to change it at home not out on a trip. That is my reason for not using it all the time besides I don't need it because I don't leave my Spyder setting. This is my last post on this thread.
Asphalt Grey
Sena SMH-10
Garmin's GPS
Once the lead is through the hole, silicone calk should seal it back again.
Just realized that I probably need to check mine and see if there is a hole that needs to be plugged.
Mine dangles inside....until I tuck it into one of the mesh pockets; pretty much exactly as you stated.
That comment was NOT directed at YOU.
That's why I quoted the person that it WAS directed to.
Lighten up a bit, please.
Originally Posted by Peteoz
As much as it pains me to say it, I have to agree with Easy Rider on the second part of his statement based on personal experience, Highwayman.
...So if you do have your Spyder constantly on a tender, it could well be that your battery is slowly deteriorating without you knowing it, and your first overnighter could leave you with a flat battery..... I will continue to attach my tender when I park at home, and keep the Rugged Geek on the F3 for backup.
Pete why would you continue to use your tender after experiencing the exact scenario Easy Rider presented?
I am one of the never use a tender crowd and with all our motorcycles and 4 syders we've never needed one.
Marilyn 2015 RTS SE6 Red
John 2015 F3S SE6 Silver
previous:
2011 RT SM5 Silver
2013 STS SM5 Silver
"common sense will prevail....but we see no sign of that"
Also haave the 16 F3T
And like others I ran mine out the left side near the suspension. It is a clear shot and easy to attach the battery pig-tail that comes with the DelTran Tender JR, and then run the SAE plug straight out and ziptie it to the upper A-Arm. Its handy when you need it and stays put without moving on the road.
No Muss, No Fuss, No Drilling.
07 Shadows, Aero, Spirit gone but not forgotten
03 Harley Sportster, 07 RK moved on
11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
Thanks! That's exactly what I did. With only 18 in there are not many options. Just used a couple of tie wraps to keep in place.
Originally Posted by loisk
There are no dumb questions... We've all been there
Re tender - I would say essential on the twins unless ridden daily. No need on the triple... it has different and improved alternator set-up vs the twins.
Disagree. It's the questions that's been asked and answered dozens of times and the answers readily available to those who look.
2011 Spyder RT-S
LtCol, USAF Ret
Proud Patriot Guard Rider
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
