Results 1 to 14 of 14
Thread: Help!!
    Active Member lois35's Avatar
    Sep 2015
    SC
    Default Help!!
    Hello Everyone,
    Okay here is my story. I hope someone can help me. I have a spyder rt 2015 limited. I was putting in a dual usb today. I tapped into the neg and positive on the connection that goes to the hot and cold gauge. I saw a video on spyder tv in how to do it. I tapped into the wires and just tried to see if it would work so i cut on the ignition and the usb work, i then cut the ignition back off. so i fed the wires and connected the usb and put it in place. i went to go try it and the dash does not light up and spyder won't crank. it does nothing when i turn the key. I dont know if i touched the wires to something when i fed them or if i connected them wrong. so i read on the internet that it might be the relay R2 pre start. so i took it out. The socket that the R2 relay goes into does not have any power going to the relay. my husband check it with his meter. so i have no idea whats going on. could it be that when i tried the usb when i switch the ignition on i didn't wait till it loaded and cut it off too soon and did something to the computer/Nanny. i would appreciate any suggestions.
    Thanks, Lois
    Dec 2015
    Oakley Utah
    Quote Originally Posted by lois35 View Post
    Hello Everyone,
    Thanks, Lois
    I would start by checking the fuses, particularly the one that feeds R2 (I don't know which one that is but maybe someone else does).
    2014 RTL Platinum
    Sep 2015
    SC
    Yep already check all the fuses.
    Thanks, Lois
    Nov 2015
    Chardon, OH
    Thanks, Lois
    It does nothing when you turn on the key.
    Just a tip, Lois. Don't just look at the fuses but take them out and check them with the meter. Both the top row and the bottom row of fuses in both boxes. If nothing happens when you turn on the key - if the cluster is dead - it's probably not a pre-start relay problem, but instead something upstream of that powering the main relay(s). The pre start relay is operated by the start button. Your problem is way upstream of that.
    Doug
    ”Freedom is not a loophole”
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Snowbelt Spyder View Post
    It does nothing when you turn on the key. Just a tip, Lois. Don't just look at the fuses but take them out and check them with the meter. Both the top row and the bottom row of fuses in both boxes. If nothing happens when you turn on the key - if the cluster is dead - it's probably not a pre-start relay problem, but instead something upstream of that powering the main relay(s). The pre start relay is operated by the start button. Your problem is way upstream of that.
    Is it possible the 'kill' switch has been moved to the kill position?
    2014 RTL Platinum
    Sep 2015
    SC
    After reading Dead F3 display and will not start thread, i went out to the bike pulled the #7 fuse and guess what it was blown. Replaced and the bike started. Damn I am happy. Thanks guys!!!
    Lois
    Aug 2008
    MA & NH
    Glad that worked out.
    Active Member juscuz's Avatar
    Dec 2015
    Virginia (US)
    Lois
    I had the same happen to me. Pulled the fuses one by one, held each one in front of a light and darn it, they all looked good but still no go. Decided to change each fuse one at a time until the culprit showed up.
    Glad to hear that you found the culprit...
    Jul 2017
    Woodbine, Iowa
    Default Great Website
    This website is great. There is a lot of help on here.
    2021 RT Limited
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Sep 2015
    SC
    YES very helpful site for sure
    Thanks again, Lois
    Active Member greybeard's Avatar
    May 2013
    indianapolis indiana
    Default usb
    Louis where did yiu find the USB that fits in that hole
    tx Paul
    Default How nice...
    Always nice to see the solution to the problem all in one thread. good service here and at a great price....
    ​2012 RS sm5
    Feb 2013
    Edinburg, TX
    Just for future reference, the kill switch doesn't stop the key from turning the computer on.
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
