Results 1 to 16 of 16
    Jun 2017
    Rapid City, SD
    Default Now that I have a trailer, what to use on the floor?
    Thinking an epoxy paint, linseed oil or??? Just to resist water, oil, and the like. Thanks
    HE>I
    2017 RT , Asphalt Grey
    Apr 2017
    North Central Florida
    Quote Originally Posted by RapidSpyder View Post
    What material is the floor made of......metal or wood ?
    You need to be real careful with this because most anything you put on it will make it slick under some conditions.
    While riding the Spyder on and off might not be a problem, if you use it for anything else a slippery footing might cause injuries.
    Active Member rmag's Avatar
    Jun 2015
    miamisburg, ohio
    Default Truck bed coating
    I used Rustoleum truck bed coating for the floor of my enclosed trailer. It has a texture to it that keeps it from becoming slippery and it wears like iron. The best price I found was about 55 dollars a gallon at Wally world.com.
    Ryde safe, Rich
    2014 RT Limted, platinum, with matching 622 trailer.
    Ultimate tall boy seat w/adjustable back rest, Corbin armrests, Spyderpops bumpskid & missing belt guard, BRP side air vents, Lamonster lidlox, cargo nets, Stebel air horn, Wrap my spyder accents......and more
    wisconsin
    I use a piece of indoor/outdoor carpet, Velcro it down in the corners and when it starts to look crappy, I cut out another piece while using the old one as a template. cheap and keeps stuff from sliding around if packed properly. Good luck! Mac
    Active Member Texas Al's Avatar
    Jun 2017
    Azle TX
    Default Floor of trailers
    I went to Home Depot and got a non-skid paint and painted the wooden floor.. It has worked great!
    2021 900 Ace , Black & Gold
    Sep 2015
    Parkesburg,Pa
    Quote Originally Posted by Texas Al View Post
    I agree,also helps with traction
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by Mad Mac View Post
    Same here. Works great so far.
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Panama City Beach, FL
    horse stall mat from Tractor Supply
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by DJFaninTN View Post
    pretty heavy isn't It???
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Jun 2017
    Rapid City, SD
    Ended up going to Lowe’s and getting similar. Guy there said that’s what he did on his also and it has worked good for him. Thanks for the input guys!
    HE>I
    Quote Originally Posted by bcer960 View Post
    not too bad. i put one in the back of my truck and I can remove it by myself. reinstalling you need two folks because of the height of the bed.
    May 2013
    Apex, N.C.
    Quote Originally Posted by rmag View Post
    Ryde safe, Rich
    This is what I did for my open trailer. Worked very well. I used this after putting about 3 coats of stain on the floor. I did not use the truck bed coating on the entire trailer floor, just the areas that I would be riding the bike up.
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    I have a drop tail trailer with an aluminum floor. I purchased this to provide traction for the rear tire, https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1.
    It helped out a lot when loading wet and the rear tire would spin.
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    United States
    On our enclosed wooden floor trailer, I used some good quality water based paint with a product called Shark Grip added to it. It gives the paint a sandpaper type surface. I have ridden our bykes up the painted ramp in pouring rain, snow and ice, and have yet to loose traction. Sherwin Williams sells it. Not bad $$$ wise. Don't buy the paint they suggest. It's $90 a gallon. I went to Lowes and got it for about $15.
    Nov 2008
    Canada, Ontario
    Default Avoid slippery
    To avoid slippery, throw sand on it and paint over. So first coat, throw sand, let it dry. Second coat.
    Jun 2017
    Rapid City, SD
    Default This is what I ended up painting it with
    HE>I
