Fuel injector
Has anyone had to replace a injector on the rear cyl on a 2008 spyder, popping from the intake,
wires, plugs, fuel filter and air has been replaced.
MOgang Member
Have you replaced the vacuum hoses?
Have you had your valves checked lately?
Have you tried a fuel injector cleaner?
Reason: More questions...
Joy
Very Happy Ryder... '09 Phantom and a '15 F3-S
If you don't slow down, they can't catch you..
If you don't give up, they can't win.
What a long strange journey its been.
Agree
those vacuum hoses can give you trouble, the 02 sensor will do that as well.
2012 RS sm5
Found the issue,
throttle body boots was the problem, cracked and sucking air.
MOgang Member
Thanks for the update! Going to keep an eye out for that problem.
Joy
