Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 97
  1. #51
    Apr 2017
    North Central Florida
    Quote Originally Posted by viiiball View Post
    I have the RT Vent Kit on order at Pitbull Powersports and once that comes in I will be talking with them about this issue.
    Good luck with that.
    I think the prudent thing to do would have been to talk to them about it and let them give it a quick look.......BEFORE you spent any money on a guess. The thing is still under warranty, after all.
    AND......I don't think that anybody here is trying to say that your wife should "just get over it".
    What we ARE trying to say.....collectively.....is that there might actually be something wrong with your specific machine because virtually NO other owner of that model has a serious problem like that.
  2. #52
    Invalid Emails
    Apr 2017
    AZ
    What color are (were) the two bikes?
    Everyone experiences heat sensations differently.
    There is nothing about the 1330 bikes, that would make them more prone to a heat issue. In fact: they were designed to reduce complaints of excess heat...
    I was wondering about this too. I have a 2016 RTL and even in very warm Arizona do not have anything resembling a heat issue.
  3. #53
    Apr 2017
    Went on a long ride yesterday; Florida....hot and humid.
    I "tested" the glove box and surrounding area a few times and it DOES get hotter than I thought.
    But it is not a problem while moving....and not any worse than 2 wheels with the exposed engine right under you when you stop.
    To the OP: Before spending a lot of time and money, run your hand over the space between the front of the seat and the back of the glove box. I had a significant hot air flow coming out there and fixed that with some stick-on weather strip. Of course that won't last forever and will need to be replaced once a year or so probably.
  4. #54
    Mar 2015
    forrest above Reno, Nv
    Thumbs up
    Haven't had a problem with heat in the glove box------- but I did put a thin piece of foam on the bottom of the glove box to keep the protective device form bouncing around. When off the bike it's in my pocket or on my belt. Maybe it's not hot enough in Nevada ------ but we did hit plenty of heat last summers trip and WILL get plenty of heat this trip to the southwest. A vented windshield keeps the humans cool enough.
    Lew L
    2014 RTS , Circuit Yellow
  5. #55
    Aug 2013
    SF Bay Area
    Curious what added accessories the bike has? Any grills in the front? Heat shields that might block air flow? Is this a used bike or bought new? What coolant is used? In the Goldwings, the use of a coolant with silicates caused the water pump to go bad. Not sure if the Ace engine is similar?
    I have just over 3300 miles on my 2018 and the chapstick in my glove box is fine. I've had a few days of 90+ temps in the California Central Valley with no problems. Air flow is a big deal and anything that slows that flow can make a difference. Guessing you're using the right coolant, plugs, oil etc. Not sure but can the gas octane make a difference in engine temp?
    2021 F3 Ltd , Magna Red
  6. #56
    May 2017
    Mesa, Arid-Zone-A
    I had some Tupperware off today. The area around the center consul box has a lot of Styrofoam. I couldn't see how any more insulation could be added. In fact, I was impressed by all the heat insulation on the Tupperware panels too. I am 2nd owner and maybe the PO added extra insulation but it does look factory installed.....
    Semper Fi
  7. #57
    Jun 2012
    Wherever the RV sleeps
    This is a completely stock bike except for the vented windshield so there is nothing as far as accessories that would be causing this heat. The engine is not overheating at all so not sure how coolant could be affecting this.
  8. #58
    Jun 2012
    Default Heat gun readings
    The RV Vent Kit came into Pitbull Powersports this morning so I we will be riding up there to get it tomorrow. Don't have an opening in Service until 6/7 and we will have left the area so going to have to either install myself or find another dealer along our travels to install for me.
    But, we did go out riding with my newly purchased heat gun. It was 86 degrees and cloudy. Heat right under the seat, next to the oil dip stick registered 135 degrees. This is the heat she feels coming up through the intersection of the seat and the bodywork.
  9. #59
    Faribault, MN
    Post overlap, I started typing, asking if it was in as you must have been hitting transmit on your post above, and didn't see your post until after I sent mine. Good example of the heat differential. I'd get some comparisons of glove box versus external ambient as well. Then after you scoop it, check again and post the differences.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
  10. #60
    Jun 2012
    Viiiball, has the '13 vent kit been installed yet? I thought you were travelling through the Springfield area and trying to get it done while there.
    As I posted above, the part just came in today and Pitbull has no openings in the service department until 6/7 and we leave the area on 6/5
  11. #61
    Dec 2015
    Oakley Utah
    The only part of the kit install you will need cutting tools for is to enlarge the existing vent hole. Some people don't even do this. I'd say go ahead and install the kit yourself, leaving the cutting to some future date if you feel you want even more air flow. Otherwise, you won't need any special tools to install this and you will see a benefit from it. Basic panel removal tool (T-30), screwdriver and drill to make the new holes in the panel for the scoop itself.
    2014 RTL Platinum
  12. #62
    Jun 2012
    Great idea. Thanks Pete
  13. #63
    Jun 2012
    BTW, heat registered right in the crotch area of the seat was 102
  14. #64
    Apr 2017
    I think this is about the third time I have suggested this:
    A small strip of stick on weather strip applied at that "intersection" will stop about 100% of the air flow coming up there.
    Plug the gap and no air flow.
  15. #65
    Jun 2012
    Yep, thanks.
  16. #66
    Default HOT CROTCH
    102 F ....... the only thing that would have an issue with this Temp ............would be an " Ice Cube ".......... seriously - you do realize the normal human body temp is 98 F +/- .....so 102F is only 4 degree's warmer .....................and I also checked my glove box temps a few times and it never went above 98 F ............. Mike
  17. #67
    Apr 2017
    More strange assertions from our self-appointed expert on everything.
    Are you really saying that if you have 98 F air blowing on YOU that it does not feel HOT ??
    SERIOUSLY ??
  18. #68
    Default Dumb * ss comments
    SERIOUSLY ??
    The way you think .....BOGGLES my mind ...... I said this in another post ----YOU DON'T UNDERSTAND WHAT YOU READ ........ I didn't say ANYTHING about Air blowing on Anyone .....and if you know even the basics about Anatomy you would know that the 98 F temp is the bodies CORE Temp not the skin Temp ....AGAIN please, please, please STOP reading my Threads and Posts ...... I make FAR to much sense for you to comprehend ....so why are torturing your-self .................and of Rant .........Love Mike ............... PS, I haven't self appointed myself to be an EXPERT about anything !!!
  19. #69
    Dec 2015
    Oakley Utah
    They way you think .....BOGGLES my mind ...... I said this in another post ----YOU DON'T UNDERSTAND WHAT YOU READ ........ I didn't say ANYTHING about Air blowing on Anyone .....and if you anything about Anatomy you would know that the 98 F temp is the bodies CORE Temp not the skin Temp ....AGAIN please, please, please STOP reading my Threads and Posts ...... I make FAR to much sense for you to comprehend ....so why are torturing your-self .................and of Rant .........Love Mike
    Mike, let it go. It doesn't matter that he disagrees with you.
    2014 RTL Platinum
  20. #70
    Jun 2012
    Default Vent kit
    Picked up the vent kit this morning. Pitbull was closed but a sales guy was there delivering a Sea Doo so he let us in and found the part. The box was open but appears everything is in there. No instructions. Should there be instructions?
  21. #71
    Dec 2015
    Oakley Utah
    Yes. Give me your email in a PM and I'll send you the PDF.
    2014 RTL Platinum
  22. #72
    Default LET IT GO
    Pete I am fine with Dis-agreeing on something / anything, this is part of human discourse ............. However it's the RUDE Personal attacks He feels are necessary in almost every comment He has made to me ............. awhile back He told everyone on this Forum that I was an " ASS " and He got away with it .... So now I'm sure He feels emboldened to say ANYTHING He wants ..... and the Administrator ( who I reported this to - TWICE ) apparently agree's with Him ..... ....................go figure .................Mike
  23. #73
    Jun 2012
    PM sent
  24. #74
    Apr 2017
    In this case, as many others, I don't really KNOW if I agree with him or not.
    Because he finds a need to try and make his posts "cute" but instead they just come out obtuse and confusing.
    But then......when he goes off on a tirade against me......the verbiage is absolutely 100% clear.....except for the part where he makes a feeble attempt to explain the original post.
    Do YOU understand what that first post about body temperature means ??
  25. #75
    Dec 2015
    Oakley Utah
    Yeah I get that he insulted you. Just ignore him.
    2014 RTL Platinum
