After reading about seats not opening the other day I decided to be proactive and make a tool to do the job now as opposed to trying to fabricate something on the road while almost out of fuel. I will keep in in my trunk in case myself or someone I am with has the issue while riding.
That's a great idea, one that I will be replicating ASAP.
.....Good for you .... I realized this as a problem a couple of years ago .../..so I made a very thin cable pull for that latch ...... I vended a few at Spyderquest .......... you should put one on the FRUNK also ...it's easy ....... Mike
Photos aren't the best but you get the idea. It works like a charm.
Push or pull? Looks like a pull system never had to fool with yet, key has worked fine but always handy to know. SS wire say from a wire welder? If so great I have some from my dads don't know the diameter, what about bailing wire? Been recommended by bunch of 2wheel buds.
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
That's what I did put it on the seat and the front trunk
Zip, great simple idea, MAN that is one well worn beadrider.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020
I just took a tie strap to the cable and hold the latch catch over and don't have to unlock anything. Took all of two minutes to do. Not the least bit worried about anybody stealing my gas or putting something in the tank. Do people even do that type thing anymore? They just rob you or carjack you.
Baja Ron sway bar, Spyder Dock, Highway Brackets,Trident pegs, Spyder Decals, Signal Mirror led strips, Utopia backrest, 5 pc. Hopnel liner set, cargo nets side/rear doors. Mesh bag front trunk, foam grips, spare trunk key, passenger armrests/storage pouch's, ram mounts/GPS, Drink holder,Phone, Passenger clamp-on drink holder, rear trunk tap light, custom plate frame, spyder fastener bolts, adjustable lower mirror wind deflectors, F4 Customs windshield -wide,tall,clear,vent,Chrome Spyder grill.
BRP paid lots of people big bucks to engineer this machine. There is more signs of intelligence on this forum than anywhere else! Love this idea. I’ll be working on this tomorrow. Thanks for posting!
If you don't change anything,,, nothing is going to change!
Have seen mostly the permanent hidden pulls. Have seen folks take the pin out and have a non-locking seat. But always nice to have a tool that way you can help your fellow ryder. I just carry two keys... will make one up cause not many do..
Gene and Ilana De Laney Mt. Helix, California
2012 RS sm5
I went one step further and just removed the stud from the seat altogether. I think I'll make one of these releases for the frunk though. Thanks for the post
Actually that " STUD " serves another function .... and this I learned from someone else's Bad experience ..... that Stud is a locator for EXACTLY where the seat pan will Position ... when it is down. Since the for and aft movement of the seat can be adjusted .... without that STUD, the seat can actually slide forward .....if this occurs ( and I know it can ) your seat will rub on your gas tank ( on an RT ) .....this can and will damage the paint ....... just a heads - up ........... Mike ......PS what I did on mine was , I wired the LATCH mechanism so it wasn't fully closed ..... It will catch when I close he seat and it stays down ....however a slight upward tug on the seat flap will release it ........ Mike
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
I changed my thinking based on your advice Mike I put the stud back in and just tied the latch mechanism back. Never even considered that gthe stud holds the alignment of the seat.
Ditto. I had some 14 gauge solid house wire so I used that. Works well, but doesn't need to be that heavy. I had to drill a hole in that metal piece where the OEM cable terminates, because the existing hole wasn't big enough for that large a wire.
l don't remember the part # off hand but I replaced the gas strut on my seat with a stronger one. I believe Mike, BlueKnight911, was the one who gave us the part # one time. It works great and can lift the seat with my helmet and jacket on it.
It can be a pain to find just the right spot but I would strongly suggest you all go through the process of getting the stud positioned just right so it goes in and out of the latch smoothly. When it's in the right spot, and with the stronger strut, as soon as I turn the key to unlock the seat it rises up on its own!
2014 Copper RTS
