Results 1 to 7 of 7
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Default previous ecu post can't find
    Good Morning, I saw a post about ecu flashing that said something about after doing this take here out and rev her up to ??? rpms in ??? gear to do something. I know this is kinda vague but it was something about getting it to work better I think. Anyone remember this post? Thanks, Mike
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Default Try this
    Google "Spyderlovers ecu" and you will get better results than searching for it here.
    ​2012 RS sm5
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    How old would you be if you didn't know how old you were?
    Nov 2015
    Tinley Park, Il
    I found it. It was from Dennis in Yodi
    It was titled Monster Fuel Injection Flash.
    Would it matter what gear you do this in. I would not think so.
    When you hold an ECU the logical way it looks to be installed is backwards. I suggest marking the ECU with a marker.
    Remember to allow a full tank of gas for the full effects of the flash to take hold. Then go out in 3rd gear at 4000 rpm and hold it open to red line. This is where the you''ll first notice the new performance. It does't seem to matter if the exhaust is all stock or free flowing. For me on my RT, I really enjoyed merging or passing up on the interstate without thinking about downshifting.
    Dennis
    Apr 2015
    Lodi WI
    Default any gear OK
    What I was trying to say is if you wind out lower gears, especially on the F3 platform, the difference isn't as noticeable as in stock form they already wind out quickly. To really MEASURE the Effects you can feel you have to put a big load on the motor. I was just trying to point out how the best feel the power from the flash. There are very few restrictions on a stock ECU in the first two gears on an RT and the first three gears on the F3. It's 3rd, 4th and 5th gears where Can-Am dialed back our fun.
    Pm me if that makes no sense?
    Dennis
    p.s. my flashed 2016 F3L with the 89 tooth sprocket can break traction shifting into 2nd gear at 55 mph. No way it did that stock.
    Nov 2015
    Tinley Park, Il
    Quote Originally Posted by Dennis in Lodi View Post
    Dennis
    What sprocket does the rt come with
    Mar 2008
    Hesston, PA
    Quote Originally Posted by wmh9680 View Post
    All RT's have the 79T sprocket...
