Results 1 to 13 of 13
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Default air compressor for tires
    Hi, since our bikes have an onboard compressor could it be adapted to top off the tires or is it too small and if so maybe a bigger compressor would do. It would be a neat feature to have with you all the time.
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Default Interesting....🤔
    Though the compressor is controlled by the sensors if you could by pass that and have a direct switch could work. Now if they added that little feature it would be great with a pull out hose to reach all tires...
    ​2012 RS sm5
    Nov 2015
    Tinley Park, Il
    Without sounding stupid, what does our compressor do and when /why
    Jul 2014
    Mint Hill, NC
    Quote Originally Posted by wmh9680 View Post
    Pg 25 of your operator's guide.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Default Short answer
    It keeps the spyder level and adjusts accordingly...if solo or double or if you add cargo it should level the spyder.
    ​2012 RS sm5
    Nov 2015
    Tinley Park, Il
    Thanks, that's what I thought. Mike
    Mar 2016
    Indiana
    In theory you could run a hose from the Schrader valve on the air bag to a tire. As long as the air pressure was higher in the bag it would fill the tire. Then the compressor would refill the bag as the pressure dropped in the bag. Granted I doubt it would be very fast, or work for long before possibly killing the pump. I don't know if it would really be any better than just using an outside compressor, except in an emergency.
    Nov 2015
    Tinley Park, Il
    Quote Originally Posted by Culpjp View Post
    Yeah, that's part of my thought, is the compressor made for something like this or could a better one be installed to replace it. Again I don't know why something like this isn't offered when some vehicles already had an onboard compressor. Maybe mount a different one in some space somewhere. Thanks Mike
    Feb 2012
    Spring City,Utah
    A LA the older Goldwings. I never understood once Honda did it this way the others (Yamaha Venture etc) didn't do it too.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member Doc - Riverside's Avatar
    Jan 2010
    USA Folkston,Ga
    Default RT Compressor
    The compressor does not operate unless the engine is running and the transmission is in first gear. It is not worth using the compressor for airing the tires when there are compressors like the one Lamont sells. It runs off a rechargeable battery, has a built in pressure gauge and the gauge can be set to a set pressure to automatically pump up the tire. This is a great feature for the front tire as they should be running the same tire pressure.
    Active Member mark4Jesus's Avatar
    Sep 2017
    Sale Creek, Tennessee
    Quote Originally Posted by Doc - Riverside View Post
    It appears that he has stopped selling these.
    2013 RT Limited.
    BajaRon Sway Bar.
    Refined Cycle's BPE2 brake pedal extension.
    Pedal Box
    2013 RT Limited , Refined Cycle BPE2 White
    Jan 2010
    USA Folkston,Ga
    Quote Originally Posted by mark4Jesus View Post
    Here is one fro Amazon. https://www.amazon.com/GHB-Electric-...Inflator&psc=1
    Sep 2017
    Reviews were not good. I wonder how folks on this forum liked it. May be why Lamonster stopped selling them.
    A thread that mentions the pump:
    http://www.spyderlovers.com/forums/s...r)-not-working
    2013 RT Limited.
    BajaRon Sway Bar.
    Pedal Box
