Page 1 of 2 12 LastLast
Results 1 to 25 of 48
Thread: air scoops
    Mar 2014
    ga
    Default air scoops
    I know this is an old issue. Bought a 2011 rt limited, have seen links for the scoops but says page does not exist. Any suggestions on where to buy?
    Invalid Emails
    Oct 2015
    morgantown west virginia
    I got mine from velocity power sports in ladson south carolina a couple years ago. think the kit was about 70/80 bucks. installed them myself. should be able to still source them from a spyder dealer.
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    I was told that the air scoops are no longer available from BRP. They may be out there somewhere, but you will have to search for them. This comes from a pretty good source.
    How old would you be if you didn't know how old you were?
    Mar 2014
    ga
    Quote Originally Posted by Devious56 View Post
    figures
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by Randy McClure View Post
    figures
    Before giving up, inquire at a couple dealers. We got them installed by our dealer on our 2012 so they know about them.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Nov 2015
    Chardon, OH
    Google search for part number 219800388. Looks in stock here:
    http://www.2wheelpros.com/oem-parts/...0388-part.html
    Double check with your dealer to see if they can still get them direct.
    Doug
    ”Freedom is not a loophole”
    What is happening with your bike; that you feel the scoops are needed?
    Dec 2015
    Oakley Utah
    Once you have the part number, you can google it for a source;
    Manufacturer
    Brand New, Genuine Can-Am PartManufacturer Part#
    219800388Item Number
    OEM1232969
    2014 RTL Platinum
    Mar 2014
    ga
    extreme heat under glove box and seat
    Dec 2015
    Oakley Utah
    This kit will definitely fix that; former owner should have had it done under the recall program.
    2014 RTL Platinum
    Sep 2016
    Lewiston , Maine USA
    Default Air Scoops?
    I ordered mine on line received them and installeed them in two 4 & 1/2 days. Follow instructions EXACTLY and cut body work Carefully and you will be pleased with the outcome!
    Active Member Schlic's Avatar
    Dec 2013
    Moscow Mills, MO
    Recall was for 2013's, not 2011's....
    Original: 2013 RT-Limited Pearl White (Bought New 07/2013 Traded @ 34,000 Miles)
    Current: 2017 F3-Limited Pure Magnesium Metallic (Bought New 07/2018)
    Current: 2020 RT-Limited Petrol Metallic Blue
    Sep 2009
    La Valle, WI
    My dealer ordered mine from BRP last summer.
    2018 F3 Limited , Oxford Blue
    Mar 2014
    ga
    Default air scoops
    Deff. want to order them. Thanks for all the input.
    Apr 2017
    Massachusetts
    Default Heat Management Scoops
    I have '13 RT L which has the scoops installed presumably by dealer. I have had some issues with the left side panel, have lost it twice during rides even at fairly low speeds. I always check the installation after checking the oil. But adding the extra air to help the cooling issues seems to add more "pressure" behind the panel and has caused it to come off. Anyone else have similar experience?
    Mar 2014
    ga
    Default air scoops
    Ok I found them on bike Bandit for $67 plus shipping. I have a 2011 rt limited, it has the honey comb vents on the panels below the mirror. Before I spend the money, will they fit?
    Nov 2015
    Chardon, OH
    Hey Randy. They don't just plug and play. There's a little cutting involved on the outer panel - a template is supplied - and you remove the inner black panel under that - called the acoustic panel. And I believe the kit will include a brace that is installed in place of that acoustic panel. A number of folks on here have done the install themselves. So, just a little work involved for the install, but they fit.
    Doug
    Mar 2014
    ga
    Quote Originally Posted by Snowbelt Spyder View Post
    I can deal with the cutting and fitting, just want to make sure they will work with me 2011.
    thanks for the input.
    Mar 2014
    ga
    Default air scoops
    Does the kit contain both scoops?
    Dec 2015
    Oakley Utah
    I can deal with the cutting and fitting, just want to make sure they will work with me 2011. thanks for the input.
    I believe all model years of RT are identical in that respect.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Yes
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Quote Originally Posted by reildeal View Post
    If you keep losing the side panels there is something else wrong. A properly installed kit does not cause that.
    2014 RTL Platinum
    Mar 2014
    ga
    Yes
    where did you get yours
    Dec 2015
    Oakley Utah
    powersportswarehouse.com they are a distributor and don't carry stock ... all these online places get the part from BRP
    2014 RTL Platinum
    Oct 2016
    Faribault, MN
    +1 What he said, I and many others have a 13RTL with scoops and have taken my Spyder to it's top speed (Not really that fast) into the wind and have never had a loose side panel.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
