Rear Tire Wear
Just returned from Spyder Fest. Have 7,000 miles on my 2016 RT-S. Rear tire is down to the wear bars in the center and can see the colored stripes. What tire is recommended as a replacement? Or what are others running? NOT HAPPY with the OEM tire!!!
KENDA
the KENDA tires most likely use the same compound rubber as 2 wheelers use, hense: the grip but don't last long....
there are hundreds of threats on this website that talk about tires, do a search...
i have used 5 KUMHO AST out back and now i'm spinning a MICHELIN HYDRO-EDGE (215/60R15) and love it....
up front i'm spinning HANKOOKS and love those....
your call, good luck....
Dan P
SPYD3R
My first Rear Kenda lasted 7,800 miles and next one lasted 11,000 miles. I let them get down to about 1/16 inch of tread left, but you must be extremely careful in the rain. I stay off the interstate in the rain for sure with any tire with very thin tread.
2021 RTL Marsala Dark Edition 4.13.2021
Lamonster Riser
Spyder Extras Docking station
Zumo XT (my own Plug & Play cable)
WrapMySpyder Carbon fiber partial kit.
Baja Ron ultra performance sway bar and end links
2015 RTS SM6 Intense Red
born on date 3/2015 (mine on 9/12/15)
Sold on 4.13.2021 33k of fun.
Tire size
Dan P
SPYD3R
What size are the Hankooks? How is your setup on wet surfaces?
There are a number of options in the 215/60/15 size. Many are running the General Altimax RT43.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
HANKOOK
HANKOOK, Ventus V4ES, 175/55R15....
i love these tires... they stick well on wet roads....
i have over 26,000 miles of smiles on them, and not yet @ the half way point as for wear....
Dan P
SPYD3R
Interesting....🤔
i have always had good results with the Kenda on my spyder. But you will find no end to information here on all the car tires you can fit on your ryde. Unfortunately there is no list of just tires or a chart with reviews. So if you read you will need a weekend off for reading...
2012 RS sm5
Heavier bike faster wear I believe too. Plus the tire compound makes a difference on wear.
Good luck on what you pick next as there are many suggestions on this forum.
Problems with size difference ?
Dan P
SPYD3R
Dan, what model Spyder do you have? I have an f3t and was wondering if I needed to make any modifications for that size tire?
We stock and install quality Yokohama tires front and rear for the Spyders. We prefer not to offer the third tier chinese brand tires.
That is what happens when a too soft center of a compound is used. My dealer replaced my Kenda very early due to an agreement at time of sale, with the slightly harder compound Kenda which was just released. It is suppose to last longer. So, some guys and gals try to stretch the life past the intended safety margin due to BRP'S bad decision, causing a greater risk of traction loss. These tires are overpriced POS.
What is most ironic, I had to sign a waiver stating the new compound had less traction and might even mess with the nanny's. Total BS....
2020 RTL Chrome Marsala Red
