Results 1 to 9 of 9
    Active Member Utah Geezer's Avatar
    May 2012
    St. George, Utah
    Default Removal of Pin Striping
    Had some pin striping added via paint a few years ago and I'm now wanting to remove it and do something different. On a car, lacquer thinner would do the trick without damaging the paint or clear coat. Anyone know if the same trick will work on the Spyder paint. Seem like it should be the same. I've done it on a car and after removing it with the lacquer thinner and buffing it out you would never know the difference. Looking at adding a wrap this time but I don't want to go over the existing pin striping since it leaves a profile through the wrap.
    Current Modes of Transportation:
    2014 Can Am Spyder RT LTD / Pearl White
    2014 Can Cam Commander 1000 Side X Side / Yellow and Black
    2007 Kawasaki Nomad Cruiser 1600 / Black with lots of Chrome
    2006 Ford F-150 Bronze and Chrome
    2014 ASICS Gel-Nimbus Running Shoes / Blue and White
    Jun 2014
    ny
    i would never use thinner on my bike or car to remove anything, it will soften the paint
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    I've used lacquer thinner my self with no problems.
    Try using it on some out of the way place (under frunk?) to see what happens
    2017 F3, SM6-basic black, plain and simple
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Saw this used on TV the other day and it looked pretty promising for removing pin stripping. Not sure if it would work in your situation though?
    https://www.walmart.com/ip/Heavy-Dut...&wl13=&veh=sem
    https://www.autobodytoolmart.com/3m-...CABEgLml_D_BwE
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Active Member Bob L's Avatar
    Oct 2014
    Massachusetts
    Easy Off Oven Cleaner. Not the ordorless kind, the stronger version.
    Bob L.
    Worcester County Massachusetts
    www.rk-mass2.org
    happy old fart stillriding's Avatar
    Apr 2010
    Elyria, OH
    Quote Originally Posted by Utah Geezer View Post
    I have actually seen a pinstriper use oven cleaner.
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by Bob L View Post
    Removed stripes from many Goldwings this way.
    2015 RT , Black
    Nov 2016
    Upstate NY
    Default Another vote for oven cleaner.
    It really works!
    May 2012
    St. George, Utah
    Default Yep
    Saw a You Tube video of this technique. I tried the lacquer thinner first and it worked well so I stuck with it. Both appear to work about the same though.
