Results 1 to 15 of 15
    Active Member solidgranite's Avatar
    Aug 2016
    North Carolina
    Default Stone Protection and Faded Black Plastic
    The nose of my 2012 RT has a layer of back "stone chip protection" paint on it, but its half gone. What can I use to refreshen it? Also much of the black plastic on my Spyder has faded to grey. Is there a product that will bring it back to deep black? Tried Armour All...didn't work.
    Feb 2017
    You might want to give Mother's Back To Black a try. I came across it at an auto parts store. It won't perform miracles but it's pretty darned good at doing what it claims.
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    Quote Originally Posted by Arion View Post
    I tried the back to black was not happy with results. Thinking of trying Hydro Dipping
    2010 RTSM5
    2010 RTSM5 , stock Stock Silver
    Oct 2016
    Faribault, MN
    I'm pretty sure Lamonster has a product Called Trim Renew and some demonstration videos of a product he tested and recommended for returning the faded black plastic back to black.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Active Member OlJim's Avatar
    May 2015
    NE Oklahoma
    I used Rustoleum spray on bedliner as a chip guard on my trailer. Works great, comes in a spray can. So far hasn't faded. You might also look at Plastikote spray. If you don't like it just peel it off.
    Jun 2015
    Hampton Roads, VA
    Default Rattle can!
    I bought a 2008 GS, the black plastic was ASH colored, it was so bad from being in the sun. Bought a couple cans of "Trim Paint" matte black at auto store. Removed the plastic (dash, nose, rear, etc.) and had a painting party. Wipe down with alcohol. Spray a coat, let dry for 5 mins, gentle warm up with a hair dryer. Repeat 2 - 3 times for a heavier application. All parts look BRAND NEW now. Doesn't fix road rash on nose or big stone chips, but you can't really see them too much now.
    I also tried expensive liquids - not even close. Darkened it up, yes. But did not last a month.
    Steve
    Quote Originally Posted by solidgranite View Post
    Aug 2016
    North Carolina
    Default Its a Plastic Stick On...like a Decal
    After taking a very close look at the "nose guard" with the faded stone chip paint, I discovered that its actually part of a plastic stick on, like a decal. I can see the edges...it runs across the nose (and under) and runs up about a foot above the nose, covering all but the badge! If I knew I could get another one, I'd consider peeling it off, and replacing it...but I don't know if they're available, or if this was a custom thing. Anybody know what I'm talking about?
    PS...I decided on Maquires Ultimate Black plastic restorer. Will probably take a couple of coats, but does a decent job. Thanks to all for the suggestions!
    Sep 2017
    INDIANA, USA
    Ziebart offers a plastic Decal coat for Paint/Stone Protection. Not sure if this is what you already have installed.
    ENJOY YOUR LIFE WITH A SPYDER
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    The best stuff I have found is Dexron 4 ATF. Works wonders on black faded plastic
    Mar 2014
    ga
    I use the armor all tire cleaner on the bike and my cars, works great.
    Jun 2014
    Lowrys SC
    Quote Originally Posted by stevencovert View Post
    Steve
    This sounds like a good idea. I've used back to black and the trim renew from Lamonster. While it does work ok, it doesn't last very long before it turns back to an ashy grey. Plus when it gets wet its streaky. I may paint mine this way.
    2010 RT Audio and Convience SE5, wider vented windshield, XM radio, digital voltmeter, K&N filter, LED turn signal strips, ISCI floorboards, Lamonster LED Headlights and Fogs, Two Bros Black series
    Jun 2015
    Hampton Roads, VA
    Default You won't regret it!
    Quote Originally Posted by jroberts650 View Post
    I spent about 3 hours tearing down all the black plastic. Used a lint free cloth and a bottle of alcohol to wipe it all down. After spraying a layer, let it sit for about 10 minutes to flash off the solvents. Use a hair dryer about 6" from surface to warm it up and "cure" fast. Apply a second coat. Looks brand new! Mine has gotten rained on a few times, sits in the sun at work. Still brand new looking. Well worth the effort.
    Steve
    Aug 2012
    CO
    Over the years, I've found all those "magic" treatment sprays are at best temporary. You have to keep using them but as soon as you stop the plastic dries out and goes grey again. The only permanent way is paint or plasti-dip.
    JLohPhotos
    2008 GS , Millennium Yellow
    Aug 2016
    North Carolina
    Thumbs up Thanks, All!
    I found a Maguiers product that does the job on the faded black. We get some intense sun light here in NC, so I'll watch to see if it fades. Sp far, its looking good.
    I used a spray of textured paint (stone chip type) from Rustoleum on the nose area. Its a rubberized sort of spray paint. The maker says its peelable, so if I don't like it, I can peel it off. Looks like I have both issues covered.
    Thanks for your suggestions! Your input is much appreciated!
    Sep 2014
    USA
    Take the decal off and use plastic dip.
    See a lot of people using that these days.
