Results 1 to 10 of 10
    Mar 2018
    mississippi
    Default Recall on 2015 RT Limited
    I took the RT in for the 3000 mile oil change and service. Had them check for recalls and Update the software. They said the only recall was a "Quality" not a "Safety" Recall on the throttle Grip. The dealer I went to didn't know anything about the issue but told me if had a problem to bring it back. When I asked what kind of problem, he didn't know.
    Has anyone had a problem on the 2015 RT Limited Throttle Grip?
    Your Dealer is mixing the terns "Recall", and "Technical Service Bulletin". (T.S.B.)
    If you go to the BRP Spyder website: you can type in the V.I.N. of your Spyder, and BRP will let you know what's going on...
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    Default TSB
    There was a technical service bulletin on the F3's about a sticking throttle grip. I called my dealer and he said if I am not having any problem with my throttle there is no need to bring it in. For those with a sticking throttle, it will be replaced under warranty.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
    Apr 2017
    RAYMOND, IOWA
    Thumbs down Throttle sticking on my 2016 RT
    Quote Originally Posted by SOlsenPHS View Post
    Was almost killed yesterday returning early from Spyder Fest in Springfield,Mo. Throttle stuck while cruise was on, had to hit the kill switch after shutting the cruise off. Was pouring down rain, terrible visibility, had cruise set at 60 and my RT started gaining speed. Upto 85 mph while I was riding the brake and trying to figure out what was wrong. After restarting it took off again. Realized the throttle was sticking. Called dealer and was told there is a "RECALL" and parts are on back order. Mine is a 2016 RT Sport.
    Jun 2017
    Crossville TN
    Default Mines Also
    We have a 2013 RTL returning from our first local road trip last year, same thing happened to me. cruise shut off but kept accelerating when i thought i should have been slowing down. I asked in another thread about this issue, and I was informed that IPS end caps from Lamonster would fix the problem and sure as heck they did. No way was I going to pay what the dealer wanted to fix the problem.
    Dave
    Aug 2008
    MA & NH
    Quote Originally Posted by montej722 View Post
    Glad you got out of that one safe.
    Aug 2008
    MA & NH
    Quote Originally Posted by Fire34 View Post
    Dave
    They wanted you to pay for the fix on a recall ?? Aren't owners being notified of this issue ?
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    I was just notified by the dealer that there are two (2) service bulletins for the 2015 RT's, one fore the 'throttle grip return, and one for the 'parking brake motor'. I was told that if I'm not having problems with that then I didn't have to worry about it. It was not a recall, just an advisory notice.
    How old would you be if you didn't know how old you were?
    Aug 2008
    MA & NH
    Quote Originally Posted by Devious56 View Post
    Thanks for the info.
    Seems to me a sticky throttle would qualify for a recall even if all units aren't doing it ?
    Jun 2017
    Rapid City, SD
    Quote Originally Posted by Saluda View Post
    Yes that could have not been good.
    HE>I
    2017 RT , Asphalt Grey
