Results 1 to 9 of 9
Thread: Dry Dipstick
    Jul 2016
    Huntsville Ontario
    Question Dry Dipstick
    Our 2016 RT has been stored in the garage all winter. Was checking for mice and fluid levels the other day and noticed the oil dipstick was completely dry. I realize oil drains from the tank into the engine, but was surprised the stick showed nothing.
    Oil was changed at the dealer just before storage, and there are no drips on the floor so logic says it should be fine.
    I know how to correctly check oil level after engine is hot, but is a dry dipstick normal after sitting for weeks?
    ....brian
    2016 RT Limited SE6
    The dry stick means nothing; until having the bike properly warmed-up and the correct oil level check procedure proves otherwise...
    Never worry: until you have something to worry about!
    Apr 2017
    North Central Florida
    Quote Originally Posted by BrianO View Post
    ....brian
    Yes probably.
    The few times I've checked mine cold, there was a tiny bit of oil on the very end of the stick.
    Active Member TexAmRider's Avatar
    Jul 2013
    Coahoma, Texas
    Default Dry Stick after sitting - No Problem
    ....brian
    I liked to have freaked out the first time my oil stick was dry. Same situation after cold storage. Spyder has a dry sump, so after starting and warming up the oil level should be shown on the stick. Ready to Ride
    2016 RTS Special Triple Black, BRP Freedom Trailer, Spyder Pops Rear Lighting Kit, Spyder Pops Full view Turn Signals, Trunk Light, Rivco Highway Pegs. Doc's Spring Tensioners, Trunk Organizer, Magic Mirrors, Foam Grips, back to Stock Windsheild, Lamonsters cat delete, Bajaron sway bar, More Farkles to come !!
    That's the key: it's a dry sump bike!
    Danbury Connecticut
    Dry dipstick.......
    Don't they have pills for that now ?
    IBA #47122
    2020 RT Limited Asphalt Grey
    Quote Originally Posted by ThreeWheels View Post
    Dry dipstick.......
    Default Not unusual....
    Depends on where you keep your level. Ideally it should be between the add and full . If your at the full after setting you may get some left on the dipstick but if your between you probably won't. fire her up and re check normally....
    ​2012 RS sm5
    Sep 2017
    INDIANA, USA
    Default Oil Check Level
    All very good TIPS. Watch for the oil pressure light to go off after starting. If light stays on Better Shut it off.
    ENJOY YOUR LIFE WITH A SPYDER
