Results 1 to 4 of 4
Thread: Fog Lights
    Jul 2017
    Woodbine, Iowa
    Default Fog Lights
    I have a 2015 Can Am Spyder RT. Of course it does not have the fog lights on the sides of the front frunk. Is there any one that makes lights that can be installed in the black inserts in the frunk?
    2021 RT Limited
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Very Active Member jnt's Avatar
    May 2008
    Minneapolis
    Default Fog lites
    Went with the BRP version. Fit. Switches fit. Work well. Mostly for visibility. W says very visible oncoming.
    08 RS/SM5 (Hers) (sold)
    15 RT-S (Mine)
    2015 RT-S , Metallic Black
    Vermont
    Default Fog lights
    I have a 2014RTS-SE6 I have LED fog lights. These are bright, and vehicles that are coming at me can see me. The spyder is lit up like a Christmas tree.
    The LED fog lights were installed last year.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Jul 2017
    Massachusetts
    Default LED's?
    I've been kicking around the idea of installing and LED strip or two into the void where the lights would be on a different version of my Spyder. More for effect, less for visibility.
    I would also think installing smaller LED lights with their own housing inside of the void would also look okay, but the angle of the installed lights would have to be right and that might be problematic. I really don't want to buy the BRP OEM stuff and then have to retrofit it into my ride.
    2017 Can-Am Spyder RT
