Garage door opener.
Thanks for the great input of ideas.
I ended up modifying the remote clip that usually attaches to the visor of your auto.
I worked great tucked into the "Start up" pull-out instructions that are tucked into the instrument pod.
Used a little double faced tape to secure it into place. Easy access for pulling up to the door and poking the button.
The hubby was impressed. Had to do that to his RT last night after he got home. He had his in the tank glove box.
He thought it was always clumsy there for quick entry.
I did take a picture of where I have it mounted, but forgot the tablet at home.
But thanks again for the great input. New I could count on your help.
Originally Posted by Easy Rider
Does your model have the "safety instruction card" that pulls out from the top of the dash board ??
I found a good use for mine.
I shoved the bracket/clip on my garage door remote into that slot....firmly.....and it is a tight fit and stays put good.
Adding a little piece of stick-on door bumper to the button makes it easier to push.
Thanks for the idea. Used your idea and worked out great. Didn't have to modify anything on the bike, just the remote bracket.
Bernie
Hummm... what about when it rains? ....brian
2016 RT Limited SE6
On my RT-S I had a blank in the center of my switch bank, so I removed the blank and cut a piece of black plastic the same size. I then drilled a hole in the center and mounted a momentary push button in the hole. I attached wire and fished it up into the speaker cavity and attached water proof connectors to the wires. I then soldered wires to the circuit board of my remote and connected them to the push button connectors. I then sealed the remote and the connectors in a plastic bag which just lays in the speaker cavity. So when I approach my garage I just press the button that is conveniently located with all the other switches. Sorry no pictures. Oh yes, I screwed the switch down in such a way that if it is removed the blank will cover the holes.
Ed
They told me not to give up on my dreams, so I went back to sleep.
Champagne 2017 RTS SE6
Quantum Blue 2012 RTS-SE5 "Bluebell, Bell for short" - Traded 09/2017
Originally Posted by siny10309
buy an updated opener that has Bluetooth and you can then control from an app on your phone.
Then I would have to buy a smart phone. Good idea, but I still have a flip phone.
Bernie
Glad I could help.
It's nice to get some positive feedback occasionally.
It is behind the windshield and under the instrument panel lip.
I don't ride in the rain......and it isn't stored outside.
I don't remember claiming that it would work for everybody.
I've had a door opener on my Honda for 15 years. Zip tied to the handle bar. Only need to change out the battery once in a while.
I've also had a MP player on my Honda. First one lasted 8 years, on my second one.
Funny
Good old English humor reminds me how much I miss monthy python
Dave
Originally Posted by quasi
exact remote I have. fits nicely in the front of the glovebox.
sorry didn't catch the st model part. let the flaming begin
I use this too. I clip it in the safety card slot above the speedometer.
2021 RTL Marsala Dark Edition 4.13.2021
Lamonster Riser
Spyder Extras Docking station
Zumo XT (my own Plug & Play cable)
WrapMySpyder Carbon fiber partial kit.
Baja Ron ultra performance sway bar and end links
2015 RTS SM6 Intense Red
born on date 3/2015 (mine on 9/12/15)
Sold on 4.13.2021 33k of fun.
Check out this item, i think it is exactly what you are looking for. plug and play mod for the spyder which adds a remote button next to the key.
https://www.slingmods.com/can-am-spy...door?vehicle=1
2015 F3 SE6
I made a weld on the remote control's opening button so that it is always in the pressed position. Take out the power of a cable (I do not remember which) connected to the positive of the battery's remote control and the other for ground to the motorcycle. Then placed the remote control with “velcro” next to the horn. I put a button on the keypad, same OEM style, next to the glove box.
The remote control goes with a little 12 volt battery.
Once memorized and installed it goes by pressing twice the button.
