Results 1 to 12 of 12
    Active Member SailnDive's Avatar
    Jul 2015
    WV
    Default Mounting the Lemonester pipe
    I got the replacement pipe today. Someone want to give me the steps for removing the old and mounting the new. I am a welder and I appreciate the quality of the fab and TIG work on this pipe. I guess this is a pretty easy job but I 'd like to hear from someone that has done it. I have some ramps so I guess I will need those first.
    Jul 2010
    Las Vegas, NV
    Default Easy!
    Easy job:
    raise bike. Loosen clamp from cat to muffler, slide onto muffler. Remove the 3, 10mm bolts from the bracket the prongs from the cat go into. Remove the 3 springs from the cat to the header. We use parachute cord around the hook of the spring, and pull aft. Helps to have a helper! Now, support the cat, and push the rubber hanger (donut) off the hook on top of the cat. I use a 16” extension. Remove cat. Harvest the black bracket with the grommets, install on bypass pipe. If it has the hook from the donut, do that first. Re install black bracket with the 3 10mm bolts. Hook the springs back up. Put pipe into muffler, install clamp. Let it idle for 10 minutes to let the ECM learn the new pipe. Go ride!
    Nice part, nice welds. Like it a lot. Call if you need to. Joe
    Joe Meyer
    Jul 2015
    WV
    Thanks Jo, just what I needed
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by SailnDive View Post
    Be prepared for a tug-o-war getting the springs put back on. It helps if you have someone to use a large blade screwdriver to guide the spring hook to the pipe hook loop.
    Darrell
    Jun 2016
    Harrington, Australia
    Default Hahaha
    When you said “Lemonester” pipe, I thought you were cleverly saying that you had received a lemon of a pipe from Lamonster
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Default Joe's got it right - Springs most trouble
    Joe's given you great instructions. The springs were the most difficult part for me. I used a puller hook and line (rope) as Joe suggests.
    Rob
    Quote Originally Posted by cptjam View Post
    Easy job:
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Sep 2014
    USA
    Automotive brake tools work good to leverage the springs on and off.
    it was much easier for me to get the springs back on.
    Jul 2015
    WV
    Default pipe mount
    That top spring looks to be really hard to reach. I've got the bike jacked up but I don't see how to reach that top spring. I guess there are three! would taking the plastic out of the way be worthwhile? It sounded easy until I looked at the spring.
    Jul 2015
    WV
    Default pipe
    Pete
    NO! great pipe...bad spelling
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    I used a 6 foot long leash for a small dog. Clips onto the rear of the spring then fished the leash to the back and pulled. Spring pops right off.
    AKA Jud Smales, Four Year Spyder Ryder!
    "Quando Omni Flunkus, Moritati"
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Driver & Passenger Gel Pads in Seat
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Break Stripe Kit from Wrap My Spyder
    2016 RT-S , stock not yet Pearl White
    Jul 2015
    WV
    Default Pipe on
    That top spring was a bear! If I have to do it again. I'll make a tool. I left the baffle out and it sounds good enough. Not too loud. Seems to really improve torque. Really well made. Thanks for the help Jo. I can only hope that we don't have a fume problem.
    Jul 2010
    Las Vegas, NV
    Default Fume/leaks
    So long as the gasket at the junction where the springs are is settled, it wont leak. Glad to help. We do the top spring first, using a length of parachute cord. Ann pulls on the cord, I direct the hook. The other two are a snap! Joe
    Joe Meyer
