Results 1 to 6 of 6
    Active Member purplepig's Avatar
    Sep 2011
    webster,ny
    Default 2015 F3 what are wires for?
    Just brought home a left over 2015 F3SM6. Next to the ignition switch on both sides are two filler caps. When I popped them open they both have wires attached. Can anyone tell me what the wires are for? Looking to put a USB connector near the bars for phone and GPS. Thanks in advance, Dan.
    [SIGPIC]
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    The left one is for heated grips, I think, and the right one is for fog lights. It might be the other way around, though.
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    Quote Originally Posted by bscrive View Post
    Nope, that is correct....
    Chuck
    Mar 2014
    can I hook up a usb port to these wires
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    Quote Originally Posted by gom View Post
    I would use the Accessory port on the F3 for USB power not the wires for the heated grip and/or fog lights. Lamonster has products to extend your USB connector to your handlebars, see his video for more information - http://www.lamonstergarage.com/usb-p...ith-extention/.
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Active Member Don'tPanic's Avatar
    Oct 2017
    Pennsylvania
    No, those wires are for switches. There are three "customer accessory circuits" with separate fuses meant for anything you want, including the usb charging. One is located under the tub in the frunk, another one is under the rear seat, and the third one is on the side, under the left service panel. They are marked with a label "Customer Accessory Circuit"
