Originally Posted by quasi
It's a 16mm which prolly won't be very efficient. i looked for a 20+mm but didn't see anything. I didn't even know about the radial design until I had already ordered my parts. may have to backup and punt!
Yeah I'm no expert on hydraulic brakes your setup may work fine for you. I just know I can't make hard stop with mine, but all normal stops it works fine. The original design by others used the 22mm and I think they have full or closer to full then I do. I hope it all works out. Even if you need to change out your master for a different one down the line you will still have saved a tone from your DIY.
2019 RTL
Farkles
BRP Comfort Seat.
Foam Grips
Lidlox
BRP Passenger armrests
Baja Ron Anti sway bar
Lamonster's upgraded BRP vibration damper.
Originally Posted by Plugger2
I totaled my 2015 rt and wanted to know if u are interrested in mine that I took off my RT.If interested will sell cheap $250.00.email me.i bought it from isci.email me if u are interested.
plugger2@verizon.net
If anybody else is interested in brake from ASCIthe offer stands for anybody..
That is a very good deal.
2019 RTL
Farkles
BRP Comfort Seat.
Foam Grips
Lidlox
SpyderLovers Sponsor
yes
There is a complete hand break unit manufactured today
I am a dealer I’ll be happy to sell you one
give me a call most anytime for pricing and availability
Originally Posted by SailnDive
I think I will start work on designing a hand brake for my RTs. I had talked about this right after I bought the bike. Is there anything already on the market that I can look at? No need to re-invent the wheel.
Dave, are you selling the ISCI kit ?
IBA #47122
2020 RT Limited Asphalt Grey
hand brake
I am working on one for my RSS. The one on the market is quite intricate and also operates both brakes at the same time. eg when you push the foot brake the hand brake operates. I am looking at one that operates separately. We should keep in touch on progress?
Done all of Canada except NWT and parts of Australia, New Zealand and areas of Europe
YES
I think this is a VERY BAD idea.....and maybe not even possible.
Don't all Spyders have "linked" ABS with stability control ??
WOW, WHAT A BUY! and here I am only 60 miles from you.
Sure, I'll buy that. call me. 304-269-6595
Originally Posted by Huked
I used the Nexus thread in your first link to make mine. Works ok but not quite as effectively as I would like.
However, if I use both hand & footbrake to stop, it stops on a dime.
I will think about the Suzuki radial m/c.
Also the silver foot peg bracket to which the slave is bolted, flexes a little outwards when the handbrake is applied hard.
2008 GS SM5, Full Moon Silver
2007 Piaggio MP3 - 250cc
Yeah I would like it to stop a bit better, but overall it works well. Normal driving conditions, just coming to a gradual stop at intersections and such, or just slowing down in general it is good. I always use both if I need to stop in a hurry, just like when riding on two wheels.
I love the look and feel of my radial m/c. You can adjust the reach some, but if you have small hands like I do it can be just at the fingertips. There is more adjustment if needed, but if you bring it in anymore then it hits the switch housing. A bit of trimming on the brake handle radius and you would clear.
Did you used the same m/c in the nexus thread, the first m/c I linked? If you did that one I think may give you getter braking then my m/c. Someone may know better then I on that though.
2019 RTL
Farkles
BRP Comfort Seat.
Foam Grips
Lidlox
The OEM foot brake used by itself will do that too, unless you have physical limitation on being able to push the brake pedal down hard. At Wing Ding 2016 I took the Trike Rider Course. Part of it was practicing panic stops. I slammed down on the brake going maybe 25 or 30 mph. Instantly, I was wearing the windshield for a bib! I'm a long way from being a skinny 100# teenager!
Yes, the Yamaha dual front disc one ( though it says Honda XS 650) with 22mm diameter bore.
