Results 1 to 7 of 7
Thread: Ram Mount
    Apr 2016
    St. Charles IL
    Default Ram Mount
    Hi All,
    Just put Tri-Axis bars on my '16 RT-S. I'm looking for a Ram Mount that I can use to mount Sirius XM head set. I'd prefer some sort of strap mount.
    Any Suggestions???
    Thanks!
    Bill W
    2019 F3 LTD
    Default Wow...!!
    There are many ways depending on where you want to mount the head set. on the bars or down on the center mount or on a cross bar on the dash. Lamont has several, JT Machine shop has some as well as other vendors on the home page. Shop around but beware of all the other goodies that will be tempting you...
    ​2012 RS sm5
    Dec 2015
    Oakley Utah
    Quote Originally Posted by 40Xshooter View Post
    Hi All, Just put Tri-Axis bars on my '16 RT-S. I'm looking for a Ram Mount that I can use to mount Sirius XM head set. I'd prefer some sort of strap mount. Any Suggestions??? Thanks!
    The satellite radio receiver isn't weatherproof, so I mount mine in my trunk. Control it with the remote. Works well.
    2014 RTL Platinum
    Feb 2012
    Spring City,Utah
    RAM-B-309-6U.jpgI used 2 hose clamps to mount this on my RT. I have one on each side. Of course remove the screws.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Aug 2013
    SF Bay Area
    On my tri-axis bars I found the top rubber part is a plug and when removed you see a threaded hole for a metric bolt. I got a bolt and the RAM angle mount ball and now I can mount anything to it. I need to get a smaller diameter washer and it needs to be 1/8' thick. (When I had a Sirius radio on my ST I used RTV to seal the unit to the mount bracket and found it to withstand rain and washing with no problems. If it poured I had a zip lock bag)
    This is the RAM mount I used.
    2021 F3 Ltd , Magna Red
    Member jmatera's Avatar
    Mar 2017
    Pawling NY
    Default Ram Mount Strap
    Hi All,
    Any Suggestions???
    Thanks!
    I use this one on my 2016 RS and it works great. Easy to put on and take off.
    https://www.rammount.com/part/RAP-SB-187BU
    2016 Spyder RS SM5
    2016 RS , Black
    Apr 2016
    St. Charles IL
    The satellite receiver isn't weatherproof, so I mount mine in my trunk. Control it with the remote. Works well.
    What remote? The XM radio that is offered from Sirius for free doesn't come with a remote. Which head set comes with a remote??
    Thanks
    Bill W
    2019 F3 LTD
