Results 1 to 16 of 16
Thread: Radiator Plug
    Sep 2013
    Johnson, Vermont
    Default Radiator Plug
    Doing a coolant flush and change on my V-Twin RS. The drain plug on the radiator seemed overly tight when I loosened it to drain the coolant. Reinstalled finger tight and then 1/4 turn with a ratchet. Filled with coolant and had a small leak. Torqued plug to spec with torque wrench. Still had small leak. Decided to remove plug and change the rubber o-ring. When loosening the plug the small leak instantly became a large leak. The area where the drain plug threads mounts into the body of the radiator cracked.
    As far as I know they coolant hasn't ever been changed and the drain plug was factory applied.
    Ordered a new radiator and prayed it was not on back order. Good news is its not
    Makes me wonder if this is a common issue with the Spyder? Anybody here of this before?
    I'm not an ace mechanic, I'm a pretty good parts changer and I've done maintenance type work on many an automotive type vehicle and have never seen an issue like this.
    Feb 2012
    Spring City,Utah
    this is a not uncommon problem that I was alerted to by my dealer. If you can remove your currant radiator,take it down to a radiator shop and have the plug soldered in. The taps are just a press fit and when you try to unscrew the plug it disturbs the press fit and leaks.Worst case it comes out. Have the radiator shop solder in the tap and you'll not have any more problems.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2013
    Johnson, Vermont
    That makes me feel better. I was pretty sure I hadn't done anything incorrectly. Too late to solder the old one since the new one is already shipped. Wonder if I should have the new one soldered before I install it for piece of mind?
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    Almost since day one, this is been a problem. The way to drain the radiator, is to remove the bottom hose.
    Never try to loosen the drain plug.
    ....and we're gonna ride, we're gonna ride.....
    ride like the one-eyed Jack of Diamonds, with
    the devil close behind,.....we're gonna ride....
    2008 GS.....PE # 2888
    Default ooouch!!!
    Has been a problem with the early models and most were recommeded to drain the radiator from the lower hose. Haven't heard of anyone here having the issue for some time.
    ​2012 RS sm5
    Feb 2012
    Spring City,Utah
    I took mine in for that service and the dealer told me they don't even try any more to remove the plug but always remove the bottom hose.Mine is a 2012.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Sep 2013
    Johnson, Vermont
    I'm changing the plugs and wires next with Baja Ron stuff. Anything I should know about removing the plugs that's a common issue? I've watched several videos on it. Airbox is out, plug wires are off. Typically I would remove old plugs, apply paste, screw in finger tight, 1/4 turn with ratchet, done. Will it be that simple on the Spyder? Just wondering after the coolant issue.
    New radiator is one thing. New cylinder is quite another
    Feb 2012
    Spring City,Utah
    there is no issue with the coolant you just need to change it every so often. I don't remember the interval now but it is in you owner's manual
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Sep 2013
    Johnson, Vermont
    Right, the issue is with the hardware.....radiator drain plug. I like to adhere to the maintenance schedule. That's why I'm doing all these things. Proper maintenance is my attempt to avoid brake downs and costly repairs. So far that hasn't worked. 2 days ago I had a perfectly rideable bike. Today I have a broken radiator and it cost $300 to replace it. Simply because I loosened the drain plug.
    Just want to make sure I don't have to dig deeper into the pockets before this maintenance cycle is over.
    Thanks for your help by the way.
    Feb 2012
    Spring City,Utah
    I didn't want to deal with the factory air box again so I removed the whole thing and replaced it with JT's air filter kit.Much easier reassembly. I also put the muffler on the airbox and it is almost as quiet as the stock.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Bossier LoUiSiAna
    Quote Originally Posted by Rob Rodriguez View Post
    The apply paste, you mean anti-seize? Ron has informed us no to on the newer iridium plugs they do not get as hot & the anti-seize will act as a insulatior. The plug grease between plug & wire is ok, not on the threads of plug to engine.
    That at may just be the 1330? Ask Ron to be sure!
    http://www.spyderlovers.com/forums/s...-Model-Spyders
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Sep 2013
    Johnson, Vermont
    He provides thermal paste in the kit. That's different than never seize. He recommends the paste. the 1330 has no plugs.
    Nov 2012
    North Las Vegas, NV
    You mean wires.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Sep 2013
    Johnson, Vermont
    You mean wires.
    Sorry, my bad.
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    The first diesel Spyder.
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by oldgoat View Post
    Now I would go for that!
    Diesel with a Turbo!
