Results 1 to 11 of 11
Thread: Air Compressor
    Dec 2015
    Salem, MO
    Default Air Compressor
    Is there some modification to allow the use of the onboard air compressor (meant to air up the rear shock) to air up tires?
    2011 Spyder RT SM5
    2006 Honda Shadow Aero 750
    1974 Rokon MX340
    1984 Toyota tube buggy (Truggy) rock crawler (highly modified)
    2008 Toyota FJ Cruiser(modifiedfor off-roaduse)
    Nov 2015
    Chardon, OH
    Quote Originally Posted by Casher50 View Post
    No. No reason to. There's so many mini air packs out there that you can either plug into your power plug in the trunk, or that are rechargeable, that makes any mods to the Spyder electrics a no value added proposition. Plus it will just speed up the already dismal failure rate of the thing, anyway.
    Doug
    ”Freedom is not a loophole”
    Mar 2008
    Hesston, PA
    Default My BRP ATV had that option
    My 2010 BRP Outlander Ltd. ATV had air ride rear shocks and it came factory equipped with a flexible air hose for that exact purpose...I have not seen anyone with that option or modification on the Spyder YET!!! I would say its doable... larryd
    Oct 2016
    Faribault, MN
    CasherD and larryd, anything is doable, but can it be simpler than getting a Hand-Held Cordless Tire inflator (Like Snowbelt is referring to) for under $50. Lamonster used to sell one and I've used one for the last year, for everything in my garage, and helped other ryders out. One charge lasts a long time, tops lots of Spyder tires (and riding mowers too).
    like this one http://a.co/0so44kt
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Dec 2015
    Salem, MO
    Thanks for the excellent advice. I have purchased a 12 volt air compressor for the times when it is needed.
    2011 Spyder RT SM5
    1974 Rokon MX340
    Jul 2016
    Huntsville Ontario
    I have a 12v compressor. First time I plugged it into the Spyder RT trunk, the fuse blew.
    I’ve been on the lookout for a 12v compressor which draws less power. Not sure, but I think the RT fuse is only 5 amp. So far, every compressor I’ve seen in stores don’t list their current rating.
    2016 RT Limited SE6
    Mar 2008
    Hesston, PA
    Default Options
    Quote Originally Posted by BrianO View Post
    Try plugging it into your SAE plug that your battery maintainer uses...This should be a direct hook up back to the battery with an easy replaceable fuse to a heaver amp one...That how I used my portable compressor on my Spyder when the air bag compressor quit...
    Dec 2015
    Salem, MO
    Quote Originally Posted by larryd View Post
    Where is this SAE plug and it's fuse?
    2011 Spyder RT SM5
    1974 Rokon MX340
    Nov 2012
    North Las Vegas, NV
    If your RT has one it would be under the seat. If you get a Battery Tender(highly recommended) it comes with an SAE connector that is hooked directly to the battery terminals.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Oct 2016
    Faribault, MN
    Or get one of the rechargeable battery powered cordless ones like I mentioned above, IF you're gonna have to purchase other stuff just to make your old one work.
    Safe Rides,
    IBA 70020
    Dec 2015
    Salem, MO
    Quote Originally Posted by DGoebel View Post
    I just ordered one from Amazon. Thanks for the advice.
    2011 Spyder RT SM5
    1974 Rokon MX340
