Results 1 to 9 of 9
Thread: Grease Job.
    Oct 2017
    N.E. Ohio, USA
    Default Grease Job.
    2011 Roadster RT SM5. I've just repaired the clutch slave cylinder, changed oil, and bled the brake fluid on three wheels. I saw at least eight grease fittings while crawling around under the machine. So what's your policy regarding grease jobs? Each year or every oil change or perhaps more often?
    Anyone have a diagram showing all the grease points?
    Ride safe!
    2018 Spyder RT Limited
    Invalid Emails
    Oct 2015
    morgantown west virginia
    Only fittings on it should be on the control arms. i'd grease them every 10/12,000 miles.
    Feb 2012
    Spring City,Utah
    lots of good ideas here. I put 45* fittings on mine to make it easier to reach them. Spects are every 12000 miles
    http://www.spyderlovers.com/forums/s...rease-Fittings
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Nov 2015
    Chardon, OH
    Quote Originally Posted by daz View Post
    The lubricate frequency for the front suspension arms was one of the few items that was changed to be done MORE often, when the new maintenance schedule was sent out in 2012. The new spec is every 9300 miles or annually, whichever comes first. And yes, 45* fittings make it a 10 minute job.
    Doug
    ”Freedom is not a loophole”
    Durham,Maine
    I tried this weekend to grease mine while it was up on the ramps, but I think I am going to wait till it's on the jack so that the a=arms are hanging down! I started on the hard side and that top back fitting is a buga.
    2012 RTL , Pearl
    Sep 2012
    Stetson, Maine
    I remove the frunk to grease mine. I do it every spring. This also gives me a chance to look things over.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Sep 2014
    East Texas
    Thumbs up Thank You
    Quote Originally Posted by safecracker View Post
    That is the only way I have been able to get to the inner fittings too. Glad to hear someone else does it the same way.
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    I removed the frunk on our to swap out for 45' and 90' fitting. I decided which ones based on the location and where I though I could get at it with the grease gun without having to pull the frunk off.
    And yes, they are easier to grease off the ground, with the A Arms hanging. Also, make sure there is enough room for the grease to get in there. You might have to back them out a bit.
    Some of mine were ran in so far, they were up against the bushing and couldn't get any grease in them. This is one of the reasons I replaced mine in the first place.
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    What grease is everyone using?
    Bob
    2011 RT-S SM5 - Black
