Results 1 to 18 of 18
Thread: Glove ?
    Jun 2017
    Crossville TN
    Default Glove ?
    We went for a ride yesterday approx. 50 degree day. My wifes hand ended up pretty cold. She ended up usig me as her warmer . My question is what kind of gloves do you guys use/reccomend for cool/cold weather riding. Thanks guys
    Dave
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by Fire34 View Post
    Dave
    Are there no heated grips on your RT? Our 2012 had heated rider and passenger grips. There are many insulated gloves out there or you could opt for heated gloves, 12 volt or battery powered.
    https://www.cyclegear.com/gear/fly-i...-heated-gloves
    https://www.cyclegear.com/gear/hotwired-heated-gloves
    https://www.cyclegear.com/gear/joe-rocket-storm-gloves
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Default And then....
    If not going to the heated gear there is always the cold weather gloves used for skiing and snow that work well. Depends on how much cold weather ryding you will be doing and how often as the heated are the best. I have found the heated grips don't do much if your hands are exposed to direct air flow so we have heated gear dual control driver and single passenger. I need more heat on the hands than the body and the wife is mostly protected by me.....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jun 2017
    Crossville TN
    Highwyaman
    Yes, she has heated grips, that was going to be a question for another thread though. When she truns them on she get the red light showing theyare on but then it goes out? I have checked all the fuses and they are good. any ideas thanks
    Dave
    Nov 2012
    North Las Vegas, NV
    Highwyaman
    Dave
    I'm no tech so I don't know where to go from there, maybe a relay is kicking off.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Gloves are a good addition for both driver and passenger. I have a half dozen pairs or so--ranging from fingerless to waterproof, to heavy winter gauntlet type.
    Also have the heated grips on both Spyders--but they don't help when it gets cold enough to wear the heaviest gloves.
    Buy what suits you best. The choices are very good at most motorcycle dealers. PS. they don't have to be can am.
    Active Member jlc41's Avatar
    Jul 2018
    New Jersey
    Fire34 , you may want to check out Revzilla they handle everything motor/ trike cycles. I like there site because they do product review videos pros and cons.
    Joe
    Lamonster Bright Ryder,
    Lamonster Bright Tail Lighter,
    Lamonster H4 LED Headlights,
    Lamonster LED Fog Lights,
    Lamonster Fog Light Ring Combo,
    Rox Riser
    Lamonster Driver Back Rest,
    Lamonster Frame Mount Drink Holder.
    Lamonster 15" Freedom Shield Wind Shield
    ******* USA flag
    Freecom 2 head sets
    Mirror Wedgies by Squared Away
    Motorcycle Dave's Tachform phone cradle
    Spyderpops Turnsignal LEDs
    Spyder Sisters Shade
    Spyderpops LidLocs
    Spyderpops front fender LEDs by Show Chrome
    Motorcycle Dave's Gel seat insert
    2018 F3L , Blue
    Very Active Member 2Paw's Avatar
    Feb 2013
    USA, Texas, Mckinney
    Most of the time I use some deer skin gloves I bought at a Tractor Supply store but when it gets really cold (December and January sometimes early February) I use a pair of these I bought when they as expensive http://leeparksdesign.com/deersports-pci/
    Ed
    They told me not to give up on my dreams, so I went back to sleep.
    Champagne 2017 RTS SE6
    Quantum Blue 2012 RTS-SE5 "Bluebell, Bell for short" - Traded 09/2017
    Feb 2012
    Spring City,Utah
    If you belong to the AMA Warm and Safe will give you an 20% discount on any purchase. BajaRon is also almost that good and he sells lots of other stuff also.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Very Active Member Lin's Avatar
    Apr 2013
    Somersworth, NH
    My wife rides as a passenger and has always been very happy with some fleece gloves she bought at a Harley Davidson dealership.
    2016 RT-S Special Series
    2016 RT-S Special , 2 tone black
    Aug 2018
    Vancouver, WA
    My passenger has perennially cold hands, especially when the OAT gets below 60 degrees. When the temps get below 55 degrees the heated gloves get put on. She uses these: https://www.warmnsafe.com/collection...-heated-gloves. Otherwise, she uses a heavy winter glove, usually with glove liners.
    I use the Warm n Safe Ultimate Touring Heated Gloves. These have turned out to be the best winter glove I've tried, heated or not heated. Once, I had to wear them in heavy rain and they got soaked on the outside. My hands were dry and warm.
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    Default IgoFar2..................see below
    Quote Originally Posted by IgoFar2 View Post
    You are lucky My wife has cold hands all the time too, and unless it is going to be OVER 60, she won't even go !! OK, once in a while she will listen to me about what the "expected rise in temp on our ride will be",,,but I BETTER BE RIGHT And there is no benefit to discussing it
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    May 2017
    Mesa, Arid-Zone-A
    I have found Deer Skin gloves to be really good. Warm even when not lined. Elk is good too but a little stiffer......
    Semper Fi
    Sep 2014
    USA
    Heated Gloves work well along with the heated grips..Never tried the passenger grips on my RT yet, but would think they are the same as for the driver grips and stay on as long as the switch is on.
    Sep 2016
    Chillicothe, Oh.
    If you have a Tractor Supply or Rural King farm store near by go check out the equestrian department. My wife has a very warm pair of gloves and a very nice pair of summer gloves both purchased in the equestrian area. Much less expensive than any motorcycle shop. For the rides below 40 degrees she breaks out the electric gloves and jacket liner.
    2015 RT , Black
    Jun 2017
    Crossville TN
    Default Thanks Guys
    For the input
    Dave
    Active Member Johndeeredoo's Avatar
    Aug 2018
    South haven michigan
    I am sorry i don't have any gloves to recommend, but I know the feeling.
    Since I am new to the spyder, but have rode snowmobiles in the past, I took my skidoo handle bar muffs off my snowmobile and installed them on my spyder.
    They do look weird, but my hands stay warm and dry, and i can feel and see all the controls.
    Mar 2011
    gaines Michigan
    What ever works. Being cold is miserable.
