Results 1 to 22 of 22
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Default 2011 RT Throttle Bodies
    I haven't heard much about 2011 RT owners replacing Throttle Bodies lately. Has that issue finally stopped occuring? For awhile, owners were relpaceing 3, 4, even as many as 5 throttle bodies on the same bike. What was the final fix.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Jun 2017
    Rapid City, SD
    Had it done on mine last August. Since there was a known issue, the local dealer put in a case on it and it was treated like warranty issue. I have since traded it in on a 2017.
    HE>I
    2017 RT , Asphalt Grey
    May 2013
    Stanton, ca
    2011 RT here and had the P0174 code. Cleaned the body per BRP instructions and has not been back.
    Bob
    2011 RT-S SM5 - Black
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Quote Originally Posted by finless View Post
    Bob
    I am also assuming you had al the updates?
    My understanding is that BRP changed something to do with the TB's that was pushed out in a update.
    We replaced ours within 6 months of owning it, 2011 RTS. Haven't had an issue since.
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Sep 2012
    Stetson, Maine
    I had mine replaced in 2013. Have not had a problem since. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Oct 2014
    Fort Mill, SC
    I was looking at the parts book and found the Position Sensor is now available as a separate unit for about $75. No longer do we have to pay $800 for the entire assembly.
    1998 Honda Valkyrie
    US Navy Veteran
    May 2013
    Stanton, ca
    Quote Originally Posted by M109Dreamer View Post
    Yes it had all the software updates done in July 2013. I bought it used and it never saw the dealer till I got it. My understanding is the 2011 has had no updates since then.
    I will say this though. My 2011 was built late 2011 so the TB change that people talk about on 2012's may have been in mine.
    Bob
    Very Active Member youngers's Avatar
    Sep 2016
    clark county indiana
    Default position sensor ?
    Quote Originally Posted by Grandpot View Post
    are you talking of the gear position sensor ?
    Oct 2014
    Fort Mill, SC
    Quote Originally Posted by youngers View Post
    No. I saw the Throttle Position Sensor (TPS) listed as a separate part.
    1998 Honda Valkyrie
    US Navy Veteran
    Mar 2011
    Jackson, MS
    Bob
    We haven't taken ours to the dealer either since then....until this last trip home, our center gauge cluster went out. And when they were troubleshooting it, they said there were 2 updates behind. So I guess 2 updates in 5 years isn't that bad.
    May 2013
    Stanton, ca
    Might have to check then. Mine went in for a "set screw in the engine" warranty service 2 years ago. No updates then so they said. Since then I have been doing my own service so it has not been back. Now you have me curious if there has been any updates for code since mid 2015. I will call with the VIN and see if I can get them to tell me if I have any. Thanks.
    Bob
    Mar 2011
    Jackson, MS
    Bob
    I don't believe there were updated codes for the TB's. The mech. told me that one was for the center display. Not sure wat the other one was for? If you find anything out let me know.
    I go and pick up the spyder today after they replaced the center console display....can't wait to see that bill....$1k+
    Jun 2010
    Las Vegas
    I had a lady in Vegas call me last week about the used 11 RT that she had recently purchased, she was having throttle body issues on it. Dealer replaced it for her and now she is having other issues. I think the dealer is going to buy the unit back from her.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Aug 2017
    Peru,Indiana
    Can the TPS cause a p0174 code? Replaced everything else, don't know what else to do. Doesn't seem like BRP or the dealer knows either, all they want to do is keep throwing parts at it in the hopes that takes care of it. I was thinking throttle body issues, but not getting the throttle body code, just the p0174. Thanks
    Oct 2014
    Fort Mill, SC
    Quote Originally Posted by jmbenge View Post
    The TPS will not cause a P0174. You are running lean on bank 2. Most likely you have a vacuum leak. Check hoses, gaskets, and O-rings. With the engine running, spray some carburetor cleaner near potential leaks. When the rpm's change, you found the leak.
    1998 Honda Valkyrie
    US Navy Veteran
    Aug 2017
    Peru,Indiana
    Grandpot, where did you see this part listed?
    Oct 2014
    Fort Mill, SC
    Cheap Cycle Parts. Look for the Throttle Body drawing.
    Actually, all the parts houses use the same reference. I have seen it in several places. Cheap Cycle Parts had the best price, but you must sign in as a member.
    1998 Honda Valkyrie
    US Navy Veteran
    Active Member BRPcare's Avatar
    Jun 2013
    Québec, Canada
    Hi there,
    We encourage you to stay in touch with your dealer as we have noted they have an open case with our Technical Department who are assisting them with this.
    Best regards,
    Karine - BRPcare
    BRPcare
    Social Consumer Experience Team
    Aug 2017
    Peru,Indiana
    Grandpot,
    Thanks for the reply, all the things you mentioned haven been checked a few times now. The vacuum hoses have been replaced, the boot on throttle body has been checked a couple times as well as the carburetor cleaner test. They haven't found any leaks. They latest now is they have switched the fuel injectors around to see what happens. This was at BRP suggestion. It starts off running ok when I first pick it up then by the time it has 100 miles or less on it, the check engine comes on with the p0174 code. It also has a new gear position sensor, plugs and wires, canister and purge valve. Not sure when the list for what can cause this code will be exhausted.
    Aug 2017
    Peru,Indiana
    Quote Originally Posted by BRPcare View Post
    Hi there,
    Best regards,
    Karine - BRPcare
    I am not sure of the purpose of this reply. I have been in contact with the dealer every two weeks for almost a year now. I have emailed BRP twice, still not fixed!
    Oct 2014
    Fort Mill, SC
    I hope they aren't charging you for the "Shotgun Troubleshooting."
    1998 Honda Valkyrie
    US Navy Veteran
    Aug 2017
    Peru,Indiana
    Thanks I will check them out. I contacted someone Friday that had the drawing of the throttle body with the individual parts listed, but not the TPS. He said he didn't think it could be purchased separately though.
