Results 1 to 17 of 17
    Oct 2017
    N.E. Ohio, USA
    Default Charging your RT from the trunk.
    Well I read a thread here about charging the RT from the trunk. It started out by saying: Remove the cover off the right side fuse box in the front truck. F6 is Labeled Key F7 is Battery."
    My 2011 RT SM5 has the fuse box on the left side looking in and all the fuse positions are full. I didn't see an F6 and F7. Are there different instructions for my machine?
    Ride safe!
    2018 Spyder RT Limited
    Active Member Doc - Riverside's Avatar
    Jan 2010
    USA Folkston,Ga
    Only works on 2014 and above RT.
    daz,
    your bike's 12 volt port in the rear trunk is hot all of the time: just plug your battery tender in there, and all will be fine.
    Oct 2017
    N.E. Ohio, USA
    daz,
    Geeze Bob thanks! I was just getting ready to install SAE pig tails on the battery and thought maybe I should ask. Of course I never thought to check it out first. By the way, I just changed my oil by only removing two panels like Lamonster talks about. 10 you tube videos say you have to remove all the left hand side panels. Not really if you are not afraid to jack your machine up and crawl around!
    Ride safe!
    From page 50 of your operator's guide. Note the 3 amp limit.
    Jan 2018
    Tennessee
    We keep our battery tender pluged in the left plug all the time when we are not riding our2011 RT it works great. Happy Trails. Ride safe. Ride often
    A battery Tender Junior is nowhere near that limitation.
    May 2019
    Canada
    Are you telling me all i have to do is plug my battery tender via 12 volt adapter with cigarette connection for battery tender and your good to go awesome
    Faribault, MN
    yep, do it all the time on my '13
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Active Member sgerksinwi's Avatar
    Jun 2019
    Wisconsin
    I have a 18 RT..So all I have to do is plug a tender in the rear truck cigarette outlet.
    What about removing fuses like ke some talk about .
    Active Member Raknid's Avatar
    Central NJ
    So on a 2012 works same? I see above^^^ mentions of 2014 and newer but also that '13 is good.
    I have a pigtail to the battery today..but good to know
    2012 RT-SE5
    Nov 2015
    Chardon, OH
    On the 2012, Raknid, the rear accessory outlet is live all the time. You don't have to swap any fuses around. It's supplied by 10a fuse F9. You can use it for a battery tender / maintainer, but any use for an actual charger may blow the fuse.
    Doug
    ”Freedom is not a loophole”
    Nov 2018
    Claremore, Ok.
    On my 2015 RTS Special Series the only port that is 'always hot' is the one in the frunk, drivers left side. Unless, of course, you switch the right side F6 and F7 fuses. Oh, and there's a frunk light in the front of the frunk that only lights up if the frunk is opened while the key is on. Been thinking of rewiring the switch so that it works whenever the frunk is open. But I don't know if the nanny would complain and keep telling me the frunk is open. Does anyone have the skinny on this?
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Quote Originally Posted by Revalden View Post
    It's more than rewiring the switch. The micro switch completes the ground circuit for the frunk light, and in the past, the frunk actuator. You'll need to find the power feed to the frunk light and connect it to an on all the time power lead. The power outlet in the frunk is one such circuit. As far as nanny no problem. The only lid open warning light on the dash is for the saddlebags and rear trunk. There is none for the frunk. Even if it's open wind will keep the lid down.
    May 2019
    Canada
    So what do I need to plug into the 12 volt power source
    Quote Originally Posted by Xander18 View Post
    If you're not familiar with electrical wiring find a friend or someone who is to help you. This is not a simple case of plug and play but it's not complicated either. But you do need to know the basics of electrical wiring and vehicle power systems.
    Apr 2018
    Corpus Christi Texas
    Quote Originally Posted by sgerksinwi View Post
    Not sure I understand your "rear trunk cigarette outlet". i have a 2018 RTL and it does not have a 12 volt cigarette outlet. All there is a double USB port, hot with ignition. There is a plastic plug covering a hole where a cigarette outlet can go but it's empty.
