Thanks Thanks:  0
Likes Likes:  1
Results 1 to 7 of 7
    Oct 2017
    N.E. Ohio, USA
    Default Charging your RT from the trunk.
    Well I read a thread here about charging the RT from the trunk. It started out by saying: Remove the cover off the right side fuse box in the front truck. F6 is Labeled Key F7 is Battery."
    My 2011 RT SM5 has the fuse box on the left side looking in and all the fuse positions are full. I didn't see an F6 and F7. Are there different instructions for my machine?
    Falling off motorcycles for over 50 years.
    NE Ohio, USA
    Active Member Doc - Riverside's Avatar
    Jan 2010
    USA Folkston,Ga
    Only works on 2014 and above RT.
    Eponymous Member Bob Denman's Avatar
    Grahamsville, NY
    daz,
    your bike's 12 volt port in the rear trunk is hot all of the time: just plug your battery tender in there, and all will be fine.
    If my Ass is in the saddle: my head is in the clouds!
    2010 RT A&C...............2014 RT-L...................2018 10th Year RT-L
    ............Gone; but not forgotten!!................... The Latest, and Best!
    Oct 2017
    N.E. Ohio, USA
    daz,
    Geeze Bob thanks! I was just getting ready to install SAE pig tails on the battery and thought maybe I should ask. Of course I never thought to check it out first. By the way, I just changed my oil by only removing two panels like Lamonster talks about. 10 you tube videos say you have to remove all the left hand side panels. Not really if you are not afraid to jack your machine up and crawl around!
    NE Ohio, USA
    From page 50 of your operator's guide. Note the 3 amp limit.
    Tri-Axis Handlebars, Zumo 590 GPS, Kradellock,
    Comfort Seat with Adjustable Backrest,
    BajaRon Sway Bar & Heim Links, SM10 Bluetooth Dongle,
    Spyderpops Bump Skid, Missing Belt Guard, KOTT Grilles
    Jan 2018
    Tennessee
    We keep our battery tender pluged in the left plug all the time when we are not riding our2011 RT it works great. Happy Trails. Ride safe. Ride often
    Grahamsville, NY
    A battery Tender Junior is nowhere near that limitation.
