Results 1 to 19 of 19
    Nov 2008
    las vegas, nv
    Default this was the reason BRP did not want us to over-fill the gas tank
    during my recent trip, i had 150 miles to a known fuel stop and stopped to top off the gas tank. at that point i had only rydden 40 miles and lost only one bar on fuel gauge. i would usually open my gas very slowly to let the pressure out slowly but when i was about open my gas cap this time, someone on a harley next pump asked me a question about spyder and i got distracted and opened my gas cap rapidly and gas just spewed out of gas tank like a geyser. my arm got soak with gas and gas just everywhere.
    i have never topped off before because my dealer made big deal about it when i bought the spyder but, during this trip because of fear of running out of fuel on a remote area, i topped off. will not be doing that again.
    now to look for decent looking auxiliary tank...
    6 states down 42 states to go
    Very Active Member NautiBrit's Avatar
    Jun 2008
    Buckeye, AZ
    Thanks for the warning, but shouldn't the gas cap have an air vent to prevent this from happening?
    George
    2017 BMW R1200R
    Alignment Specialist bone crusher's Avatar
    Aug 2008
    MD
    Quote Originally Posted by aka1004 View Post
    Huh? I always top this bike off and I always open the tank without worrying about the speed at which I take off the cap...
    Strange...
    Bone Crusher
    If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
    Nov 2008
    las vegas, nv
    Quote Originally Posted by NautiBrit View Post
    spyder fuel tank is not vented
    Nov 2008
    las vegas, nv
    Quote Originally Posted by bone crusher View Post
    Strange...
    i get alot of pressure built up in my gas tank.
    when i fuel in hot weather and my gas tank is empty, i can hear the sound of metal buckling due to pressure being let out of tank.
    my dealer even heat wrapped the exaust pipes on both side and added heat shield to gas tank to prevent this but it still happens.
    i am on my 3rd evap canister and i never over-filled but i think all that pressure is pushing gas into canister.
    Registered Users gazey's Avatar
    May 2009
    Hobart, Tasmania.
    i am on my 3rd evap canister and i never over-filled but i think all that pressure is pushing gas into canister.[/quote]
    Hi Akka104,
    Just curious,
    Can you tell me why you have had to change your evap canister. Is this somthing that has to be change often and how do you know it needs to be changed . I know I have one on my car with 200K on it and its never been changed.
    Andrew Gaze
    2008 Full Moon SM5 PE#979
    I am one very happy owner
    Registered Users captainryder's Avatar
    Apr 2008
    Blue Springs, MO
    It strikes me as somewhat funny.... aka1004..... you hear "metal buckling" ??? Are you sure you are on a Spyder or is this a submarine passing 5000 ft
    But I will keep this in mind, never thought of it, but have always topped off, and then usually start driving. Never open up the tank again till I'm due to refill.....
    SE5 Moon (delivered Aug'08), Cal-Sci windshield, Zumo 550, tank bag, backrest & luggage rack, kurykan Iso grips, and SwingWing pegs, NM's 4" risers, Russell Day Long Seat, Buschtec hitch, Alumna MCT trailer
    Blazing Member fastfraser's Avatar
    Feb 2009
    Orangeville, Canada
    Strange...
    Never had a problem . May-be you have a exhaust leek under the tupperware causing a heat build-up ?
    Aug 2007
    Springfield, MO
    I just looked at the book and I'm wondering if you have a bad purge valve. The tank is under pressure (4psi) but there is a test procedure for the purge valve. Has your tech check that?
    Mar 2008
    Allegan, MI
    Modern vehicles meeting emissions requirements are no longer directly vented. Venting is through the purge system and evap canister. If you open your car or truck gas tank, you will find the same type of pressure build-up. The engine heat directly below the Spyder gas tank (or many motorcycles) does not help the pressure situation. I've has other warm bikes spit back when opened soon after filling. Look at how your gas gauge changes between hot and cold conditions to see how much volume change there is. The Spyder has a small tank, and a nearby evap canister. Not much room for expansion or error. I'm not surprised that it spit back at you after a short ride following the initial fill. This situation also seems to be responsible for the gas fumes many of us smell regularly. Live and learn, I guess. Inherent in the breed.
    -Scotty
    Registered Users FANG's Avatar
    May 2008
    Pensacola, FL
    Guess from years of working as a gas pump jockey back in the old days - I remember the first time I took off a gas cap and heard the sound of air escaping from the cap. The old timer at the station who was checking under the hood (yea it was a long time ago) told me to always take a gas cap off slowly. Force of habit I just turn slow and listen for air to escape. - by the way I have tasted a lot of gas by turning the cap quickly before I learned. LOL
    Bill
    Very Happy Spyder Owner
    Gulf Coast Spyder Ryders -- look for us in the Ryder Group/Club shortcut on the homepage.
    New Ryders always welcome!!!
    Nov 2008
    las vegas, nv
    Quote Originally Posted by gazey View Post
    Hi Akka104,
    Just curious,
    Can you tell me why you have had to change your evap canister. Is this somthing that has to be change often and how do you know it needs to be changed . I know I have one on my car with 200K on it and its never been changed.[/QUOTE]
    i had bad gas fume problem and brp and dealer were trying different things to resolve that and canister was changed in the process. it was not my request to replace it.
    Nov 2008
    las vegas, nv
    Quote Originally Posted by captainryder View Post
    when it's warm and my tank is empty, it sounds like a shaken bottle of soda is being opened and metal buckling as tank is retracting to original shape i guess.
    usually, i do wait till i am pretty low to fuel and this was first time i opened my gas cap to fuel when fuel level is that high.
    Nov 2008
    las vegas, nv
    Quote Originally Posted by Lamonster View Post
    yes. purge valve was checked and replaced everytime they replace the canister.
    Mod Maniac ataDude's Avatar
    May 2008
    North Texas
    ...now to look for decent looking auxiliary tank...
    Uh, oh. Don't post the results as the naysayers will tell you it's dangerous and stupid. PM me with what you wind up with... I may want one.
    ata = allergic to asphalt
    My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
    There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
    My Spyder:
    Aug 2007
    Greeneville, TN
    Hmmm...Maybe I'm pressing my luck. I always top off, to the very top (if Lamont isn't riding off without me anyway). I've never had any problems.
    Occasioinal gas fumes but not bad. I have gotten some of that with most every motorcycle I've owned.
    I have both my exhaust pipes wrapped from the head back almost to where they join. I think that helps the heat as I don't feel near as much on my leg as I used to.
    Ride Forrest Ride!
    Jul 2008
    Kissimmee, Florida
    [quote=aka1004;103065]
    now to look for decent looking auxiliary tank...[/quote]
    go to http://www.justgastanks.com/store/in...pbo6picp1ea973
    Aug 2008
    MD
    [quote=effgjamis;105797]
    Oh no you don't! You can only have water or beer in an external tank, not gasoline (jk)...better check state laws as well on this topic...
    Bone Crusher
    Registered Users Latemarch's Avatar
    Aug 2008
    Cape Girardeau Missouri
    [quote=bone crusher;105817]
    Quote Originally Posted by effgjamis View Post
    But if it's in the trunk it can't be an external tank.....
    A member of the rabble in good standing.
    A happy owner of a yellow SE-5.
    NMN Risers, Mudflap Lights, Fender Tips, Center Brake Light w/ Triple Play, Throttlemeister, Madstad Robo-brackets, Madstad windshield, CHAD windshield, Canisterectomy, Exhaust wrap.
