Results 1 to 21 of 21
Thread: RT won't start
    Jul 2016
    Ohio
    Default RT won't start
    Finally it's not snowing or raining and my RT won't start. I had it on a tender throughout the winter. I have 13 volts coming from the battery and all lights are working, with no fault codes. What could be the problem?
    2016 RTL , Red Pearl
    It'd be real handy to know something about your ryde...
    What year is it?
    How old is the battery?
    What is it doing when you hit the starter button?
    (Is it clicking; or just doing nothing?)
    But some quick things to check:
    Has the emergency stop switch been engaged?
    Was the bike left in gear when you parked it?
    (Are you putting your foot on the brake pedal, when you hit the button?)
    Jul 2016
    Ohio
    What year is it?
    It is a 2016 RTL and I am not getting any sound when I push the starter. My foot is on the brake and the bike is in neutral. It was covered and on a tender throughout the winter months.
    How about the kill-switch?
    After this one: you're going to have to actually check your battery terminal connections...
    ...and then: the fuse panels!
    Sorry... I've got nothing else.
    Jul 2016
    Ohio
    What fuse would cause the starter to not engage? Terminals tight. Bob, just let me use one of your bikes, the weather is so nice!!
    Default Try this
    Just to make sure.... flip the kill switch back and forth a few time and then set it to run. Then follow the starting steps you already know...mode button brake etc. If the battery has 13 volts and even a bad connection will give you a click.
    ​2012 RS sm5
    Quote Originally Posted by jaybird1 View Post
    I'm planning on busting mine out tomorrow: AFTER the yard work is done!
    Sep 2015
    Parkesburg,Pa
    Don't forget to hit your mode button,make sure kill switch isn't on and if not in neutral step on the brake.
    Jul 2016
    Ohio
    Quote Originally Posted by slick999 View Post
    The winter months caused my brain to freeze!!! Hit the mode button and KABOOM!! Thanks guys and gals.
    Sep 2015
    Parkesburg,Pa
    Yes easy to do after a long winter,I have done the same.Enjoy the start of the season.
    Jul 2016
    Ohio
    My wife said "don't you feel dumb"? I said not when I take off tomorrow, I will feel pretty good!! Enjoy
    Jul 2017
    Massachusetts
    BAHAHAHAHA! I'm with you Jaybird! I did the EXACT same thing yesterday!
    "Piece of crap, why did I even buy you? I can't believe I wasted all this money on a three-wheeled pile of turds. Oh wait, aren't I supposed to push this button first?"
    VROOOOOOM.
    "Sorry honey, I love you."
    2017 Can-Am Spyder RT
    Oct 2016
    Faribault, MN
    Reminds me of last year, I could NOT get my spyder in reverse for nothing, I pulled and pulled on the shift paddle. Oh, WHAT's that HUGE R button for??????
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    you[and i] forget a lot when it sits for over 5 months. i had to sit there and think about both the
    start procedure and reverse working. this year and before. now i find out after 1 small ride
    the rear shock air pressure is kaput hasnt made it 2 years.
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Member crw's Avatar
    Jun 2017
    Griswold Ct
    Default crw
    how about forgetting to hold the brake down for 10 min.
    2013 RT , LAVA BRONZE
    Active Member spyderider1's Avatar
    Jan 2018
    Wisconsin
    I did the same exact thing a couple of weeks ago. Wasted some perfectly good cuss words until I remembered........
    brake, mode, and little black button.
    Life is good when sitting on a Spyder!
    LORD GRANT ME THE SENILITY TO FORGET THE PEOPLE I NEVER LIKED,
    THE GOOD FORTUNE TO RUN INTO THE ONES I DO LIKE,
    AND THE EYE SIGHT TO TELL THE DIFFERENCE.
    2016 Spyder RTS
    Sep 2016
    Lewiston , Maine USA
    Default RT won't start?
    I know my 2012 SM5 has to be in a certain "Mode" to start! Just my two cent opinion!
    Jan 2018
    Tennessee
    Did you do all your pre trips. Lights,turn signals, oil and water, gas, tire pressure. Bank card. All the good stuff. Happy Trails
    Active Member Docster's Avatar
    May 2017
    Perry Hall, Md
    Another reason I ride mine year 'round even here in Baltimore. It's good for the bike, the riding skills and reduces memory loss....
    2011 Spyder RT-S
    LtCol, USAF Ret
    Proud Patriot Guard Rider
    2011 RT , Yes Blue
    Ahhhhhhhhhhhhhhhhhhhhhhh. Got to love those senior moments. Unfortunately, they seem to be happening a bit more frequently these days.
    Jun 2015
    St Petersburg, Fl
    Wink
    I don't understand. I don't remember ever having a better memory than I have now.
