Results 1 to 8 of 8
    Sep 2016
    clark county indiana
    Default hot doggie my 1st nanny limp !
    HAHAHAHA , man what a windy day it was any way ! first day in the low 50`s , mid 70`s high , had been getting ready since yesterday , rolled out the 2012 r-t , cranked her up let her idle up too 1 or 2 bars on the temp gauge , shut down , check oil --- great back into garage , now next morning , went too put lunch into the frunck , here is where I think I made my nannie a little mad , had been turning the key too the unluck front position , heard the click , but didn`t open tried 3 more times , in doing this I turned the computer on as in next step too start , turned off and noticed I had been turning the wrong direction , I was opening the seat , so all put into place rolled her out , suited up , let her idle while I put on helmet and jacket , off we went ( weeeeeee ) rolled through the 3 way stop , ( no traffic at 5 a.m. in the country side ) went about 1 1/2 miles away from home , bammmm my nanny said heckkkkkk no , the throttle went too almost non existence on power , and flashed check engine , the gear position went too 2 then flashed ( R ) then 1 then back too (R ) and the reverse tail lights were on also ! limped back home ---- > you know it was kind of peaceful S L O W ride back could hear some of the frogs and crickets in the wooded areas as I creped along the road at a whopping 7 m.p.h. got back home , took the key out ... arrived back 9 hours later took her for a little spin no problems shifted just fine ,speeds of 40 too 50 , ( I am thinking nanny had a vision of something terrible ahead , turn around will robinson , danger danger ... ) it works for me anyway ... will let all know if something happens tomorrow !
    Northern Kalifornia
    You seem to possess an awareness that many others don't have. All to often fighting to overcome mild resistance can be fatal. Spooky.
    Nov 2013
    Central Texas
    Just for giggles, make sure your battery connections are tight. As blueknight911 has suggested put Star washers under the nuts. (I did) Loose connections on the battery terminals are a common cause of the Nanny throwing all sorts of codes, and causing general mayhem.
    Sep 2016
    Default thanks will check it
    Quote Originally Posted by oldguyinCT View Post
    thanks for the information will check on that battery terminal deal
    Default NANNY
    .... IMHO the Nanny is much too sensitive .... it doesn't take much of a blip to set Her off ..... However removing the key at least 6 inches & 5 minutes time .... from the ignition switch allows Her to re-boot the system ...Mike
    Nov 2015
    Chardon, OH
    Well, don't forget the connections under the seat, either. Especially the ground connection. Remember that you have to get a wrench on the back side of that bolt. There's a nut back there.
    Doug
    ”Freedom is not a loophole”
    Sep 2016
    thanks all for the added information , took her on a ride too work this morning , did just fine , although , when I pulled into my parking area , came to a stop ready for the reverse , it gave me the ` ye old nanny walk , so parked it , back on 8 hours later rode home fine , stopped at a local place close to home , turned her off , took off again , seemed to operate pretty good ! ( will double check the battery terminals )
    Default Glitches
    Hope it is just the occasional glitch. I get them now and again then gone. If it happens while driving I just shut her off wave the key over my head three time put it back and fire her back up and keep on ryding. Usually clears it up. Like your attitude taking it in stride... best way....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
