Has anyone installed one of these?
Battery jumper port for all Spyder 2013+ If so, safety issues?
https://www.tricledusa.com/product-p...ll-spyder-2013
First time I've seen one. Looks like it would get a lot of water on it when it rains. I took some heavy duty wire and attached it to the battery. Caped it off and layed it under the seat on our 2011 RT. That way all I have to do is raise the seat and umcap it and hook jumper cables to them.
Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
2020 Petrol Blue Metallic RTL
Dont see the need. How often do you plan to jump start your Spyder? For the once in blue moon you need it, just remove the battery cover hatch.
Jumping the battery is not a common event.
So maybe the need for this is not great.
There sure would be a benefit to having this rather than removing the frunk on an F3 to access the battery though.
As far as water getting on it-so what. It is covered by the plastic cap seen in the pics. No water will get on the plug.
I guess if you are planning for every "worst case" this isn't a bad idea.
2017 F3, SM6-basic black, plain and simple
I don't know if it is possible, but can the battery be jumped from the remote terminals in the left side (from the riders perspective, right side if you are looking into the frunk) of the frunk that are under the black plastic cover? JC, you would most likely know more about this than I do.
Yes, but removing the frunk bucket is only 4 push pins on an F3 and gives you direct access to the battery.
His profile says he has a 2015 RT Limited. Accessing the battery or the remote terminals is really easy either way. I guess just a matter of personal preference.
I just installed this on my 2016 RT Limited, after having to jump it on the road. It will be a lot quicker and easier than unloading the frunk and opening the battery compt. It was easy to install, and I thought it was reasonably priced.
2022 Spyder RT Limited Sea to Sky Mystery Blue
i keep 2 small vise grips in the frunk to put on the posts for better grip
for the jumper cables. hope i never need them.
2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
and some little stuff. setback utopia backrest, baja ron
sway bar, oem adj. air deflectors, marlin gps compass,
lamonster fbb foot pegs[modified brackets], lamonts
vibration damper, rock guard, and side case stiffener kit,
. brp comfort seat. , fomozas and
altimax, magic mirror mts, and wide mirrors.
[joyce & irvin toms]
This feels most useful for a trickle charger.
2020 RT Limited in the ultra cool Deep Marsala Dark edition.
Baja Ron Anti-Sway Bar, LED reflectors, Lamonster USB Charger (and phone mount), Can-Am Low Windshield, X-Creen Tour Variable Windscreen Spoiler Blade, Power Commander, Dilithium powered Flux Capacitor (not yet fully functional).
Maintained by Lou at Pirate Powersports.
I can see that this would be a option to have and hopefully don't need to use it very often. It would also be a very easy way to trickle charge a battery or connect a battery maintainer when needed. As far as the possibility of getting water in around the cap, it is brass and should not hurt anything. About all commercial vehicles have these on them with and without caps on the terminals.
2015 RTS, Corbin armrest, Lamonster Spyderdock outfitted for Garmin mount, Spyder cuff with cup holder, highway pegs, Lidlox, Bumpskid, Swaybar, XM dock
My (previously owned) BMW Z4 had this type of set up under the hood (bonnet). Battery was in the trunk (boot). Had to use it once to charge the battery. Easy to use and no messy battery terminals to deal with.....
Semper Fi
