Results 1 to 19 of 19
    Mar 2018
    Brownsboro TX
    Default What are these holes for?
    2013 ST SM5. What are these hole for?BBC8190A-B345-4C5C-A8BF-8D722DE61480.jpg
    Various bikes since 8 years old
    1999 Honda Nighthawk
    1999 Honda Pacifica
    2005 BMW 1150 RT
    2007 Yamaha Roadliner
    2007 Yamaha Royal Star Midnight Venture
    2013 Can Am Spyder ST
    Sep 2014
    USA
    Looks like your missing a bracket or support that goes in that area.??
    But then I could be way off.
    Mar 2013
    Oz
    Are you missing the belt guard maybe?
    Active Member Huked's Avatar
    Mar 2017
    Watford City, North Dakota
    Default Guard
    Quote Originally Posted by Mahaflac View Post
    You are missing the plastic belt guard. #40 in the pic. that is for my 2011 RS, but should be the same. http://www.2wheelpros.com/oem-parts/...7213-part.html. Make sure you look it up to make sure it is the same. If you scroll down in that link, it shows all the diagrams for the years and bikes that part number fits.
    2019 RTL
    Farkles
    BRP Comfort Seat.
    Foam Grips
    Lidlox
    BRP Passenger armrests
    Baja Ron Anti sway bar
    Lamonster's upgraded BRP vibration damper.
    2019 RTL , Asphalt Grey Metallic Dark
    Mar 2018
    Brownsboro TX
    Default Thanks
    Thanks. That is exactly what it was. Ordered one and is on its way.
    1999 Honda Pacifica
    2005 BMW 1150 RT
    Mar 2017
    You are very welcome.
    2019 RTL
    Farkles
    BRP Comfort Seat.
    Foam Grips
    Lidlox
    Bossier LoUiSiAna
    There was a campaign out a bout that the stock bolts were too short or something. All should have been found & taking care of by the dealer. You very well may get it for free depending on how dealer & BRP cares can handle it.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Default There you have it....
    Gotta love the quickies...question, some answers and solution on the way...isn't this place the best....
    ​2012 RS sm5
    SpyderLovers Sponsor capt.jim's Avatar
    Mar 2008
    homestead, FL>
    They were installed with capnuts which would vibrate loose.
    Check up around the front sprocket to make sure it isn't lodged up there, when they fall off that's where the belt will send it.
    Another problem solved quick. Way to go folks.
    Oct 2015
    Lynden, WA
    Default Belt Guard
    1+ on the belt guard bolts.
    My guard came loose and was flopping around the belt.
    Get longer bolts and use lock washers and decent nuts to secure everything.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Jun 2017
    Hackettstown NJ
    And Loctite
    Mar 2018
    Brownsboro TX
    You solved the last one so fast, I thought I would throw another one at you. Does anything belong in this hole. Not sure why the pic is turning sideways
    1999 Honda Pacifica
    2005 BMW 1150 RT
    Sep 2013
    Boynton Beach, FL
    Not on my 2014 ST-L.
    Ride Safe,
    Roger
    2014 ST-L
    Sep 2014
    East Texas
    Default The Lower Belt guard bolt
    This would be for the top bolt in the belt guard. The other holes for this would have had bolts with capnuts.
    Mar 2018
    Brownsboro TX
    Default thanks
    Kinda what I was thinking, but wasn’t sure.
    1999 Honda Pacifica
    2005 BMW 1150 RT
    Bossier LoUiSiAna
    Glad your getting to know sorry if seemed ruff at first.
    Miles of smiles ahead get to meet & learn more at events when you can it will help hone the farkle list & get a first person view if not all out demonstion.
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Sep 2013
    Boynton Beach, FL
    If you look at a parts diagram, I think you will see that the upper belt guard has no forward bolt, and the forward bolt on the lower belt guard is attached in a different location. I have no idea what that threaded hole is for. Probably for something when that frame is used for another model. The RT-S and RT-L. You have an ST.
    Roger
    2014 ST-L
    Mar 2008
    homestead, FL>
    That hole is for the rod/linkage going to the air ride switch.
