Results 1 to 7 of 7
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    Default Thunder QQ Baffle
    Anyone have one of these that can send me some measurements? In particular, the OD of the sleeve portion and its length plus the overall length of the entire baffle?
    Been calling Lamonster but no answer or call back from Jakob....
    Chuck
    Default Big T Baffle
    Quote Originally Posted by hypurone View Post
    The OD is the same as the ID of the muffler pipes..... I made mine and the tapered part was about 2.5 inches long , this is where I drilled the holes .....works fine ..... Mike
    Jun 2016
    NorCal - Northbay
    Not sure this helps me as I have the Akrapovic Straight Shot which I believe has a larger inlet diameter than the stock piece and I'm using a different mid-pipe (not Lamonster) and I don't have a micrometer that can reach in far enough to measure its diameter
    Chuck
    Jun 2016
    NorCal - Northbay
    Default Finally!
    Got the info needed. Whew.....
    Chuck
    Active Member T.P.'s Avatar
    Oct 2016
    APPLE VALLEY, MN
    I have a 2017 F-3 from Pitbull Powersports with their 1330 Primary Muffler Replacement Pipe.
    I also have the Thunder QQ baffle from Lamonster garage.
    The OD of the baffle is way smaller then the ID of this pipe.
    T.P.
    Active Member fencepost's Avatar
    Apr 2010
    Thorn Hill, TN
    You can call Big City Thunder and get a sleeve if you are concerend about the gap. I have installed the baffle both ways and the only difference was the time and work it took to fit the sleeve.
    SpYderman
    Jun 2016
    NorCal - Northbay
    Quote Originally Posted by fencepost View Post
    as stated in post #4, I got the info needed.
    I'm done with my project!
    Chuck
