Results 1 to 4 of 4
    Sep 2016
    Clifton Springs, NY
    Default F3 Limited floorboard
    Hello, looking at buying a left over F3L. I know you can adjust the floorboards in different positions (1-5). Can you also swivel them into different positions or is that part stationary. Thanks.
    Wayne Bishop
    2015 RT-S Special Series
    2017 F3 Limited
    Greenville Tx
    No they are in a fixed angle but it feels very comfortable. When I installed Lamonsters black diamond boards I added a 1/4 inch spacer to get it at the OEM height. You can fab any kind of wedge spacer you want to give to more kick back. All it is is a fixed mounting bracket that the boards bolt down on.
    2017 F3 Limited
    Very Active Member JkRbbt's Avatar
    Mar 2010
    SD
    I bought the CanAm floorboards for my F3S. Correct, they are fixed, but I agree that the angle is very comfortable. Good luck.
    Sep 2016
    Clifton Springs, NY
    Thanks everyone.
    Wayne Bishop
    2017 F3 Limited
